IAG catch can system
GooseTuned
Winfield
New Mexico
All the Raptors, Explorer ST, F150, and some other toys
Some companies do make cheap catch cans for sure, I agree. This is an AOS though, it's different.
IAG has been making this AOS for almost 10yrs. It's new to Bronco, but bronco also hasn't been around for 10yrs.
This is a gold standard for what it is.
Sidenote: I purchased a $20 catch can setup off Ebay for an old race car back in 2012 because the catch can craze was cheap even back then. Heck, people even had PVC catch can builds at teh time lol.
When this came out for ecoboost it was a no-brainer to use. I also helped IAG with ecoboost AOS dev a few years ago though too so knowing what these do and how they work is important to me as well. It's about passing that knowledge on to the community as well.
I get people may think it's too expensive for them, but to a lot of people this is well worth the money.
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
I run an iag aos now, had the ford performance catchcan setup, but dumped it for the AOS.
much better design and fit with the AOS, no maintenance.
What didn't you like about the Ford Performance setup?
Epiphany
Upstate
'24 Bronco
For one, the passenger side separator rubs on the hood and as a result FP put a stop on their sale...
box986
Paul
NNJ/NEPA
Oh, I'll have to check if that is the case with the 2.7 as well (I already have it installed). Maybe it's just the 3.0 that rubs?
Epiphany
Upstate
'24 Bronco
It is just the 3.0 FP separators in the Bronco Raptor that rub.
Here's from when I installed mine. Note the height of the pass side separator. It actually sits more in the center of the engine at the firewall, and the driver side is down low near where you'd find a brake booster.
Ford Bronco IAG catch can system 20241016_185200%20copy-X4
Now look at the height of the FP separator on a 2.7. Similar location and the higher of the two for that application but still well below those on the Raptor.
rayofsi
Staten Island, NY
Raptor Gen2
Spoke too soon. Less then 2 months after install. Leaking coolant at the banjo fitting.
rayofsi
Staten Island, NY
Raptor Gen2
The Ford performance kit rubbed the paint off my hood. And one of the hoses kinked a bit during install. But it was ok.
My iag kit is leaking coolant at the banjo fitting. Hoping to hear from iag soon. Bought this mid April direct from them.
GooseTuned
Winfield
New Mexico
They will take care of you
rayofsi
Staten Island, NY
Raptor Gen2
all fixed up now, IAG took care of it, i guess 2 months is pretty early for failure, i also replaced the good side banjo with viton orings at the seal from banjo to aos. i believe they come stock with nitrile, and its pretty damn close to the turbo.
GooseTuned
Winfield
New Mexico
They're a great company!
