IAG mud flaps w/ Ford factory rock rails?
Glen24
Glen
Illinois
24 bronco
Who has installed IAG mud flaps with Ford factory rock rails?
Started installing them today on the drivers side front. Seems like it bends yo much and hits the tire.
The first bracket that you install, in the directions it says mount using the top two push pin holes. If you do that the bracket does not match up to those holes.
crewchief182
JT
MI
2021 Bronco, 2006 Mustang
I installed a front pair and they were tricky but worked and look good. They made a world of difference also in regards to keeping the sides of the vehicle cleaner.
GoodThunder
Dale
Austin, Tx
4 Door Badlands, Velocity Blue
I haven't had any issues with mine, other than it being tricky to get the self tapping screws in with little space to work. They are exactly what I was looking for, some extra protection while being pretty un-noticeable. Assuming you are talking about the ones in this video?
Did you add the oem rock rails, I didn't think the Wildtrak came with those?
JL8jeff
Ewing, NJ
Which IAG mudflaps did you get, they have the I-line which are smaller and the larger curved ones that are similar to Mabbet. I went with the larger ones on my base Sas and I have the hoop steps which have a similar rail to the rock rail. No clearance issues with the rail, but I also have ProComp wheels that are 17x9 with -6 offset so they hit the inside of the flap at full turn. I ground them down to get extra clearance. They fit fine with the stock wheels/tires.
