- First Name
- Dusty
- Joined
- Oct 4, 2021
- Threads
- 18
- Messages
- 394
- Reaction score
- 1,275
- Location
- Riverside, CA
- Vehicle(s)
- 2021 Bronco Base 2-Door
- Your Bronco Model
- Base
- Thread starter
- #1
Hey guys ICON's billet Front UCA's and rear Upper and Lower Suspension Links have been announced to our dealer network. Here's the low-down:
ICON 21-up Bronco Billet Front Upper Control Arms
Improve your Bronco’s suspension performance with ICON’s Billet Upper Control Arms. Ford designed the new Bronco with great off-road capability right out of the box, but we just couldn’t help squeezing even more performance out of it. These billet UCA’s free up movement to allow maximum travel for performance shocks and coilovers.
The all new Delta JOINT PRO provides a host of durability and performance improvements compared to our standard ball joints and uni-balls, including up to 90° of free articulation to maximize suspension travel without bind. It’s also beefier and fully rebuildable.
Heavy Duty FK Rod Ends at the chassis pivots provide precise handling with smooth, tension-free movement compared to bushings. ICON’s proprietary Rod End Adjuster Sleeves allow for easy, precise adjustment of caster and camber, right on the vehicle. This is essential for fine-tuning your suspension after any lift or other adjustments.
ICON Billet Upper Control Arms are CNC machined from 6061 billet aluminum with a satin anodized finish. The hybrid H-beam cross-section is light-weight resists bending forces better than tubular arms.
Hit the trail with the confidence of knowing your suspension components are covered by ICON’s Limited Lifetime Warranty*.
*Lifetime Warranty covers arms and components except: Delta Joint PRO is covered by ICON’s 1-year warranty on rebuildable joints. FK Rod Ends are covered by the manufacturer’s warranty.
At the time of this writing, these are not even on our website yet, so I can't include a link (I'll update this post when I have one). But several of our dealers have already listed them and are taking pre-orders, so check with your favorite ICON dealer!
NOTE: ICON is working on a full line of long travel performance shocks and coilovers for Bronco, which these arms will be featured in our multi-stage complete suspension kits. We'll also be doing tubular versions of our arms. I'll post about all of these here on the forum as the info becomes available
