- Dusty
- Oct 4, 2021
- 18
- 394
- 1,275
- Riverside, CA
- 2021 Bronco Base 2-Door
- Base
ICON Vehicle Dynamics is excited to announce our Vehicle Specific 2.5 Series Coilovers for 2021+ Ford Bronco!
These ICON 2.5 Series coilover shocks are engineered to give the 2021+ Bronco outstanding performance off-road and a smooth ride on the street. Our desert-tested, race-proven shock technology provides superior damping, tuned specifically for the Bronco's suspension and vehicle characteristics. CNC machined shock ends and mounts, body and shaft lengths and coil springs have been custom configured to squeeze maximum travel and articulation out of the Bronco's suspension geometry while providing increased lift height to safely accommodate up to 37-inch* tires. Like all ICON shock absorbers, V.S. 2.5 Series shocks are 100% rebuildable and 100% revalveable.
When used in conjunction with ICON tubular or billet front Upper Control Arms and Rear Suspension Links and 35" tires*, these coilovers can yield up to 14" of rear suspension travel and up to 11.5" of front suspension travel.
NOTE: ICON V.S. 2.5 Series Coilovers are available in pairs (front or rear) or as part of our Complete Suspension Systems, Stages 3 through 8 (CLICK HERE).
BRONCO 2.5 INTERNAL RESERVOIR COILOVERS
BRONCO 2.5 REMOTE RESERVOIR COILOVERS
BRONCO 2.5 REMOTE RESERVOIR COILOVERS WITH CDCV
BRONCO 2.5 REMOTE RESERVOIR COILOVERS WITH CDEV
IMPORTANT TECH NOTES
- Factory set for approximately 3" suspension lift (for Sasquatch-equipped Broncos; approximately 4" lift for non-Sasquatch Broncos)
- Threaded body allows for further lift height adjustment at installer's discretion(adjustable from 2.5-4" of lift height)
- Increased wheel travel, up to 14" rear, 11.5" front
- 100% Bolt-on, no cutting or welding necessary for installation
- Vehicle specific design, engineered for maximum performance with Bronco suspension geometry.
- CNC machined 6061 aluminum components with a black anodize finish.
- High strength alloy CNC machined lower bar pin
- ICON engineered coil springs with long-travel, triple-rate rear coil spring
- FK rod end bearings for extended longevity and minimal deflection.
- Coilover Shock Measurements eye-to-eye:
- Front: 24.53" extended; 17.60" compressed
- Rear: 28.90" extended, 18.36" compressed
ICON COILOVER VARIANTS
These precision-manufactured, custom valved Internal Reservoir coilover shocks yield the maximum travel possible along with superior ride quality and suspension performance both on- and off-road. ICON coilover shocks are fully rebuildable. Our coil springs are custom engineered specifically for Bronco. The big 2.5-in diameter shock body and piston provides efficient damping and cooling, while the massive 7/8" diameter shock rod provides the strength to withstand abuse. The rear shocks are oriented shaft-up with unique triple-rate coil springs to achieve the most rear suspension travel possible.
48600 - 21-UP BRONCO FRONT 2.5 VS IR COILOVER KIT
48610 - 21-UP BRONCO REAR 2.5 VS IR COILOVER KIT
To provide for sustained shock performance at speed through rough terrain, this variant of the ICON VS 2.5 Series Coilover adds remote reservoirs to greatly increase shock oil volume and heat dissipation surface area to resist overheating and cavitation under hard use, which can lead to damper fade.
48700 - 21-UP BRONCO FRONT 2.5 VS RR COILOVER KIT
48710 - 21-UP BRONCO REAR 2.5 VS RR COILOVER KIT
These coilovers feature ICON's exclusive Compression Damping Control Valve (CDCV) for precisely dialing in your suspension performance. CDCV controls fluid flow under compression, allowing you to achieve the perfect tune whether driving on the street, slow-crawling through the rocks or mobbing across the desert at full throttle.
48700C - 21-UP BRONCO FRONT 2.5 VS RR CDCV COILOVER KIT
48710C - 21-UP BRONCO REAR 2.5 VS RR CDCV COILOVER KIT
ICON's Top Of The Range coilover features lightning fast, precise electronic shock tuning, on-the-fly, at any speed and in any terrain. Focus on driving and let ICON Intelligent Control (IIC) read the terrain and make near-instant adjustments via the Compression Damping Electronic Valve (CDEV) at each individual shock. Control the system wirelessly through the IIC app on your phone. Once configured the system functions without driver input.
48700E - 21-UP BRONCO FRONT 2.5 VS RR CDEV COILOVER KIT
48710E - 21-UP BRONCO REAR 2.5 VS RR CDEV COILOVER KIT
43501 - 21-UP BRONCO IIC INSTALL KIT (REQUIRED WITH CDEV)
- 2-Door models will sit slightly higher than 4-door due to weight difference. For all models, final lift height is subject to variations due to equipment weight and load-out.
- When running 37" tires, Up-Travel Limiters are required to prevent tire contact with wheel well liners at full compression. These are sold separately (p/n 611075 front; p/n 611074 rear)
- When running Remote Reservoir, CDCV or CDEV rear shocks with STOCK rear lower suspension links, Reservoir Hose Clamp Kit p/n 611072 is required (sold spearately)
- When running Remote Reservoir, CDCV or CDEV rear shocks with ICON TUBULAR rear lower suspension links, Reservoir Hose Clamp Kit p/n 611073 is required (sold spearately)
- No additional Reservoir Hose Clamp Kit is required when running CDCV or CDEV rear shocks with ICON BILLET rear lower suspension links, as billet clamps are included with the links.
- On Broncos equipped with factory crash bars (non-Sasquatch models), ICON High Clearance Crash Bars are recommended when running up to 35" tires.
- When running 37" tires, factory crash bars (if present) may need to be removed, and further trimming may be required, to prevent rubbing (not recommended by ICON).
