Idling down - Feeling Stupid
Fordified1
Bob
Mid South Texas
ā€˜15 Mustang ecoboost, 4wd Excursion, ā€˜69 Mach 1
Like someone has already mentioned, coolant continues to flow throughout the system after you shut the vehicle off.
No. Our Broncos do not have an electric water pump. Try again.
Fordified1
Bob
Mid South Texas
Ok, I’ll try again. Never said they did. Coolant continues to flow after engine shutdown. A pump isn’t necessary.
Ok sparky you do you.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
PSA
I’ve read many times about letting your turbo ā€œidle downā€. I assumed this meant not to turn off your engine immediately. Let it idle for a few seconds before turning it off.
Nope. I experienced it today, and feel a bit stupid.
If you wait about 45 to 60 seconds after stopping and putting it in park, the engine noise changes. Your RPMs don’t, but you can hear the engine ā€œidle downā€.
Very important for the life of your turbos…….or so I heard. šŸ˜‰
I follow the decades-old Mack Trucks instructions.
"Idle engine 3 minutes before shut down."
This is all about allowing your turbo to cool down. I.e., at idle the turbo is no longer working but oil continues to pump oil thru it. That oil carries away heat allowing the turbo to cool down. Oil can boil within the turbo under harsh conditions if your were to abruptly shut down, which damages the ball bearings.
Anyway, with all gasoline and diesel turbocharged engines, I follow the Mack rule.
VirginiaHeritage
Frank
ā€˜25 Bronco HE
There are safety margins baked into the algorithms that will defeat the process. While annoying, it is not detrimental to engine components designed for it.
Eh, I don’t really have faith in this, because it cut off once at a stoplight after I had been ON IT and I ended up cursing at it, and myself for forgetting to push the goddamn button.
RedDawg
RedDawg
Erik
PHX AZ
I never thought this thread would get contentious. I just thought I’d catch some shade for not understanding my engine.
I’m stupid and naive 😁
Fordified1
Bob
Mid South Texas
Someone else shared the info. Post number 4 in this thread. Cool it, Turbo.
Did you even read my post before commenting on it? I basically said in extreme circumstances would be the only reason to leave it idle for a little bit before shutting down. I don’t think you understand how Turbo chargers work. You know they spin 100,000+ RPM and get glowing red about to melt?. one guy with a Subaru said that the water boils away and freshwater comes in. I’m gonna take that as maybe in a Subaru maybe in a bronco I don’t know. What is your problem? Do you also have a problem with me believing that we should only run full synthetic oil in turbo cars also? You’ll probably trade your car before it gets over 100,000 miles. I’m gonna keep mine forever. I will maintain it how I like and that will obviously be maintained better than yours..
Willub
Billy
Massachusetts
I was simply pointing to the info that quotes someone from Ford explaining what I mentioned. I also made a joke using word play, since you resorted to name-calling for whatever reason. All good, I’ll stop quoting you now.
HoosierDaddy
__ Eric
NW. Indiana
I Come from the old school diesel world. I always let the 12v in my F250 cool before I shut it down, just carry it over to all my vehicles, now that they are all turbos except my NA Cobalt but I let that cool too, 400k must be doing something right.
Biggest problem is, to this day, habitually waiting for the glow plugs on start up .... haven't had a diesel since 2017-ish. Lol!!!
HoosierDaddy
__ Eric
NW. Indiana
Temper temper.
Ford Bronco Idling down - Feeling Stupid 1788273954920-iz
