If Broncos are like Lego Sets...
The First Edition and other high end trims are like the super complex city buildings or Star Wars sets that are made in exactly one way and are not torn apart and built into something else. They are basically art pieces, no doubt, but the work is all done once you get it and finish it the first time.
The Base on the other hand is like the giant tub of Legos with no/lost instructions that I had as a kid in which I just used my imagination to make things with, then tore apart and then rebuilt into something else. Over time, I would just get another set, make it... get bored and then dump all of the pieces into the big tub.
If you got the Base and budgeted an additional $15K, you could do all kinds of things over time to make your Lego set really customized with your imagination and rebuilt different ways for different seasons/use cases if you want.
Bottom Line:
I am getting the base 2 Door with nothing on it. I will then get bigger tires a few months later and then keep adding from there. Also, anticipation for the "next thing" is a big motivator for me.
How about you, which Lego set are you getting?
...And what do you think of the Lego metaphor?
Bottom Line:
