Illinois Plate Type?
Karl_in_Chicago
Karl
Chicago
Dumb question but I've never registered a truck or SUV in Illinois, only cars and motorcyles . . . will this be registered as truck or passenger? I'm pre-filling out the title and reg form online and it pulled the VIN info properly and populated most of the fields . . . but it also says Truck (with a dropdown for other values). It's body on frame so definitely truck construction, no problem with that, just don't want a "B" plate if that's what this ends up as. If it IS a "B" plate then I'll opt for a FF memorial plate (also no problem) as I live in Chicago, just figured it would be easiest to ask other Illinois Bronco6G folks.
Dealing with Ill SoS can be painful enough as it is, just want to have all my ducks lined up so that forking over ~$5K is as smooth as it can be.
TIA!
Ford Bronco Illinois Plate Type? 1684342540392
Karl_in_Chicago
Karl_in_Chicago
Karl
Chicago
Passenger, mine does not have B plates
Thanks! I know they did some changes a while ago that were supposed to address how "trucks" are mainstream but not being directly affected then I didn't pay all that much attention.
Trees
Chicago, IL
Bronco 2 Door
I was jazzed about the b plates until I realized that you can't park on most streets and like you are technically forbidden from using lsd
So just registered mine as a passenger vehicle
Headsong
Not b. Couldn't transfer.
Hkak45
K
Illinois
21 Bronco Black Diamond
And there have been talks about charging more for "trucks" on toll roads so passenger plates may save you money if that ever passes. This is reason I'm getting passenger plates on my maverick also. Not sure about Chicago though as everything I do is banned in Chicago so don't pay attention to their fees or rules.
