- Greg
- Jan 27, 2021
- 18
- 170
- 318
- Winchester, Virginia
- Harley Davidson FLTRUSE
- Badlands
I’d like to cost-effectively reduce or eliminate the possibility of tie-rod breakage on my 22 2 door Badlands Man-Squatch.
Original plan was Peak Suspension tie rod sleeves, but my local trusted 4x4 shop recommends strongly against. They say this is a very dumb idea that increases the chance of costly damage. Shop states that breakage occurs when suspension droop exceeds geometry, and load when turning exceeds limit…and if I brace the OEM tie rod, all I’ll do is transfer the load to the rack and break it. Shop recommends these options:
a - Carry a replacement tie rod and be ready to swap on the trail.
b - Avoid breakage by limiting use of front locker in full droop. It still might break, but care in use reduces risk.
c - Replace the tie rods with upgraded assembly end to end to handle droop without breakage. Apparently upgraded rods allow improved flex to avoid breaking the rack. (Costly)
d - Limit down travel by about 1/2” with straps.
e - Anticipate better Ford OEM parts as upgrade/replacement later i
I’m led to believe that with mild wheeling (easy east coast rock crawling and trail riding) that limiting down travel will not be a major issue, as long as I have the front locker and I retain up travel. Clearly the sta-bar disconnect will be less effective but will still help somewhat.
I’m inclined to try it (option d) pending e. I don’t want to spend a grand or more on replacement tie rods.
Anything I’m missing with this thought process?…. I want to keep this vehicle “forever”. It will never be lifted, and it will retain stock SAS suspension otherwise.
Thanks in advance for knowledgeable replies.
