With the endless wiper sizes for different vehicles, there is no way this is a one off wiper blade. Oracle produces lighting products, not wiper bladesDumb question, but this isn’t a one-off unique blade is it?
Ok, Cool. What about wind load?Appreciate the feedback but your calculations are off and YES this was "contemplated" and evaluated during R&D which we are way past including months of on-road testing. As mentioned before this has been extensively tested (at up to triple digit speeds). Drag is not an issue.
You are driving a truck shaped like a brick and you are concerned with wind load? . Joking of course but no it is not an issue. I want to be sure that the structure of the product is not being confused. While the visible portion of the design is a polycarbonate housing, the mounting structure is comprizsed of gusseted steel brackets utilizing the factory mounting hardware. So we are utilizing steel structure for mounting not the polycarbonate shell. So our design is using a similar type of steel mounting structure as something like this photo below with much less drag than this design.Ok, Cool. What about wind load?
Good question, this is not a one-off blade we are just supplying 16" blades to replace the factory 17" ones. The 17" wipers wipe up into the blacked out portion of the windshield that does not need to be wiped and slightly clips our housing so we throw in a set of new wipers for youDumb question, but this isn’t a one-off unique blade is it?
Both clearance light colors pull less than 1a.I’m trying to plan ahead for my aux switches. I found the following specs:
Driving Beam Specifications:
- Raw Lumen Light Output: 18,000LM
- Effective Lumen Light Output: 14,200LM
- Peak Intensity: 420,000CD
- Total Wattage: 240 Watts
- Total Amp Draw: 14A @12V DC
- Beam Angle: 40° Driving Beam
- Max Projection Distance: 1Lux@648M
- Color Temperature: 5500K-6000K
- Advanced Optic Design for Optimal Visibility
Do you have available the amp draw for the clearance lights? I’d likely want them (the ambers if that makes a difference) paired on the same aux switch with my fog light backlights and want to make sure that the switch where I currently have those is going to provide adequate current. Thanks
Can’t wait to get mine!A little teaser video:
For the clearance lights the Amber will override the white so a neat option is to connect the White to ignition fuse power (see below) and the Amber to the parking lights so when the amber parking lights are on the amber clearance lights are on.So 14amp, run it on aux 2, but where should I do the clearance lights?
