Is there a soft top roof mounted light bar that is doesn’t make extra noise?
Lak34ers
Troy
Seattle
I would like a roof mounted light bar but I can't deal with whistle, drone or humming sounds. Is there a light bar that exists that won't drive me crazy with extra noise??? Please let me know if you have a light bar and your thoughts on the noise.
Thank you!
AceGoliath
Charles
IL
21 Bronco OBX SAS , 22 Maverick XLT, 10 Fusion SE
Thank you!
Something like this in black to match the soft top will probably be your best bet once they release it.
https://www.bronco6g.com/forum/thre...-light-bar-system-for-2021-ford-bronco.42168/
https://www.oraclelights.com/produc...2021-ford-bronco?rq=mk_ford~md_bronco~yr_2021
Matt
Pearland, TX
2022 Black Diamond Bronco / 2021 Powerboost F150
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Lak34ers
Lak34ers
Troy
Seattle
Sorry, short answer: NO
Light bars make noise because of what the wind does on the back of the cooling fins. We DO sell light bar covers which help prevent that noise. But this isn't just a Bronco thing... it's been an issue with all roof mounted bars across all trucks.
Check out our kits here: https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
The wind diffusers/silencers are here: https://www.4x4truckleds.com/led-light-bars/wind-diffusers-accessories/
Thank you for the response. It is disappointing because I think they look good and have a purpose but I HATE driving around and listening to rattle, whistling and other noises. You have to put up with enough noise just from having the soft top so I can't do extra noise. Finally found a rattle that was driving me crazy from the soft top plastic box below the latch. A little weather stripping to tighten it up and it was fixed. Have the single a pillar pods and they seem great so far and diode elite fogs. Just like to add one more big light option. Maybe Oracle will come through with there new design for the roof or someone will built a light bar mount for just above the plastic front bumper. Can't pay the $1700 for the baja solution.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
the Baja XL Kit doesn't make noise BUT it will mess up the airflow over the soft top which will cause the soft top to flap more
