Looking for help with Ford Performance Winch kit
Wheelman23BL
Wheelman23BL
North Alabama
bronco
Man if you can get it scanned, that would be even better. Ive got a guy who can measure it. Hes got a kit in his garage, but this would be precise. Didnt wanna waste his time if you can do this. DFX file if possible. Thank.you so much!!! My email is [email protected]
Blue Hen
Delaware
18 Suzuki Vstrom 650XT, 22 Bronco Base MT SAS
Since Everglades comes with a winch stock. Why can't your dealer just use a VIN from an Everglades model.
Wheelman23BL
Wheelman23BL
North Alabama
bronco
Because its discontinued, also discontinued from buying individual parts across the board. They could pull it up and show the part, but once you clicked to get into the parts order page it says its no longer available. That is from my local Ford dealer parts manager.
C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
Ford Bronco Looking for help with Ford Performance Winch kit 1786588666778-g7
No separate parts for this,not even the bolts. If one of these guys can`t help you,calling Warn would be your best bet.
Wheelman23BL
Wheelman23BL
North Alabama
bronco
Let me know if you still need the measurements, I have a kit in the shed I can dig up and take measurements.
I have a neighbor that may be able to scan them, I'll check- If he can what is your preferred file format?
Hey checking back to see if that was gonna be a reality with scanning the brackets
Brutesquad
Las Vegas
Bronco Badlands
OP, My apologies for taking so long. here are the drawings for the brackets you mentioned. Let me know if there are any other measurements. Most of the measurements are the same between the two except for the position of the stud and the cut off corners on the one. the face view is on the side the stud sticks out of the bracket. The stud looks similar to a wheel stud, wide head on back, splined press fit, then threads.
Wheelman23BL
Wheelman23BL
North Alabama
bronco
Brother, you are a saint. I do not know how to thank you!!!! Can I send you some money???
Brutesquad
Las Vegas
Bronco Badlands
NO, we are good. I know what its like to try to get parts or info on parts that are not available. Just glad I could help.
I forgot to mention, they are made from 1/4 inch (6.5mm) steel
Wheelman23BL
Wheelman23BL
North Alabama
bronco
You saved me a massive headache. Seriously appreciate it!! Thank you again, sir!!!
MNBigfoot
MN
Well done!!!!
