Mabett Launches V3 Tailgate Table pull-out double-platform!
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
Buy "V3 Tailgate Table pull-out double-platform" directly for $239.99 via this link: https://www.amazon.com/promocode/AW6UFY1397IOJ
  • Product Description
  • Pull-out dual platforms, Quickly get more table space
  • Made of iron, Gray Powder-Coat finish.
  • Sports a Sleek, Foldable Design
  • With 2 Cup Holders
  • Fully Bolt-on, no-drill installation.
  • Quiet, no rattle cargo solution.
  • Supports Up to 75 lbs.
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! 1
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! 2
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! 3
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! 4
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! 5
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! IMG_6362
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! IMG_6396
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! IMG_6398
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! IMG_6403
Ford Bronco Mabett Launches V3 Tailgate Table pull-out double-platform! IMG_6406
smiths65
Niskayuna, NY 12309
'21 RAM1500 BigHorn
Cool product, but why do your links never work?
adamruiz2001
SoCal
Ford SVT Lightning
Link works for me... But I am on my PC, I know the links don't usually work if using a phone.
smiths65
Niskayuna, NY 12309
'21 RAM1500 BigHorn
Just checked, I'm the opposite...works on phone, not PC. Lol, riddle me that ;)
Mabett
Mabett
Mabett
China
www.facebook.com
I updated the promo code, it will take effect in 4 hours, please use your computer to open Amazon, log in to your account, and then click on the promo code, the offer will be displayed at checkout
85crawlrunner
Josh
Southern Utah
21’ Wildtrak
Mine arrives next Tuesday! I’ll let you know what I think of it when it’s in.
emulous74
Seth
Austin, TX (Pflugerville)
'19 ZR2 Bison D , '23 Bronco 2DR, MT
Got mine today and installed it.
First, I watched the video and read through the instructions. There was no way to get the little bars through the opening on the right (when the door is open) side of the tailgate, luckily there is a rather large hole next to them, so I was able to carefully put the bar on the backside and screw into it from the front. The Left top side the little bars went in the way the instructions show. Also I ended up replacing the washers provided as they were to small and feel into the hole when tightening up. I just used 1/4 SAE washers that were wider. Otherwise the install was relatively easy and one person can do it on their own.
2nd observation is the unit itself is dark grey that doesn't match anything on the Bronco. I would of preferred it to be black.
Overall for the price it seems to be well made with an enamel type of paint. Would be awesome if it was made out of food grad stainless-steel, but I'm sure that would a couple hundred of dollars to the price. The slide out piece seems fairly stable (as long as you pull it out to the farthest it will go). I see why it's not possible, but wish the top piece could be deployed without the side pieces deployed. And for those of you with the slide out tailgate, you can deploy both at the same time.
One downside is the closing "locks" you need to push in hard to get them to close, which means you either have to hold the tailgate door or move it to the max position. Hopefully the will close easier with wear.
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
What am i overlooking. It's not heavy but to heavy to hold it up to the brackets and screw it in at the same time. Am I missing a step?
I read the instructions. Video?
emulous74
Seth
I was able to hold it up and get the first upper screw in and then hold it up for the second one. I'm only 145lbs and 5'11 so most folks can do the same.
KCW
K.C.
2017 Mazda 6, Kawasaki Nomad
I just installed my table tonight. Very pleased!
Only issue was that the M6 screws that come with the kit are two different lengths and the instructions don't specify locations. There are 4 short and 6 long screws. I believe the six longer screws should be used on the lower mounting points and the four shorter on the upper mount. If you use the longer screws on the top they will hit the door and damage the paint.
Mabett, please consider changing the screws to the shorter 16mm length or specify the lengths in the instructions.
Great table, I highly recommend it.
I didn't measure the screws in the kit, but I believe they are 16mm and 20mm long. I just grabbed some M6x1.0 16mm that fit the top, so I didn't have to disassemble what I already mounted.
Mabett
Mabett
Mabett
China
www.facebook.com
