- Craig
- Oct 13, 2022
- 7
- 94
- 161
- Northern Virginia
- Bronco, Raptor, Jeep Grand Cherokee
- Wildtrak
- #121
16 tends to get a lot of traffic (like the old 19). Groups will often pick a channel and some privacy codes (note, they're not private nor encrypted, but the help your group stay rallied up.Got my MXT575 today, with the whip antenna, and cable. I have my license as well. I will admit I haven't read this entire thread. I have a couple of procedure/listening questions.
1. Is there a call channel, as Ch19 on a CB, that folks listen to and then switch over?
2. Have folks had good luck using FMS handhelds with the the GMRS? Midland told me it would work, with all due respect to them, they are trying to sell me a radio.
3. Due you have to tune the antenna and radio once installed? If so, does the CB device work, or do I need a different one? If I need a different one, what brand are others using?
4. For the antenna mount have folks found it works better in the front or rear....keep it clean please??
That's it for now. Thanks...Dave MERRY CHRISTMAS!!
Get an SWR meter (see the page on SWR notes in this thread). If your antenna is tuneable, you'll want to get good SWRs (something under 2.0 and much closer to 1:1).
DO NOT USE a CB SWR meter, you'll fry it. SWR meters are tuned to a frequency range. CB radio is 26-27 Mhz. GMRS is UHF, around 462 Mhz.
Find a spot that works for you. Some guys have had some really ingenious mounting locations. You'll want to play around with the coax length and how it's run through the horse and the position of the antenna (does it need a ground plane, etc.). Position won't matter nearly as much as proper mounting, mounting height, and SWRs. Love the hood mounted stuff some of the guys have thrown up on the thread. Good luck!
