The Beaz
Shad
San Francisco
@0321_Bronco Great write up! Question - If I'm looking to do a similar install, do I need to order the Micromobile MXTA24 Low Profile Antenna Cable to use with the mirror mount and ghost antenna? Or does the antenna cable that comes with the 575 work for that?
Depends on the kit you order from Midalnd. I ordered when they first launched the 575, and the only kit option was the magnetic antenna, so when I ordered the 6db antenna, I had to order a new cable. Now it looks like they have kits with the cable and 6db antenna and a mount included
jclark
Jeanette
Mid-Michigan
I was referring to the magnetic antennae that comes with the "base" 575. All of the Midland bundles include a hardware accessory for mounting (for tube mount) that I won't use, so I was going with the base 575 radio and adding accessories for the install I wanted - and didn't know if the antennae cable with the base was reusable with other mounts/antennas.
After some research, it appears it is not - so I added the low profile cable to my order.
$100 off $500 with promo code PLANT right now makes this a great deal. If you were planning on getting the 575 anyway, either using one of their bundles, or by adding accessories, you are just shy of the $500 - so add in a pair of handhelds, and the handhelds are almost free with the current promo...
The Beaz
Shad
San Francisco
correct, the cable with the base is not reusable,
jclark
Jeanette
Mid-Michigan
The bundles are the better deal if they have the configuration you want... for me, since I was going with the ghost antennae for my installation, the bundle was sold out.
phuoc_ly
Phuoc Ly
Derby, KS
2021 RAM 1500 Limited
**Updated w/SWRs at end of thread**
So, to get this out of the way, I'm a licensed HAM and GMRS operator (nerd alert). Never cared much for mobile HF operations but having a mobile HF rig is fun (if you're into that sort of thing). And operating a radio shack is a whole different matter! Setting up an international shot from the beach campsite and hitting an eastern European station from a mobile HF rig is if fun. But I digress.
Please note, this is NOT a debate of HAM and GMRS, HF, or VHF, long wire antennas, the existence of aliens, Yagi’s, etc. I'm simply describing my mobile comms choice for this vehicle based on my planned use/application and the subsequent install.
2M VHF and 70cm UHF are much more practical for licensed mobile use. But again, require more radio manipulation than I care for while driving. That said, I've always run a 2M radio in my rigs. This time, given the maturity and wide adoption of GMRS, I made the decision to use a GMRS radio as the mobile unit (installed) and keep either an HT or mobile 2m/440 in a case in the back. Get the license (more like registration-no tests), it's $30, lasts ten years and covers your whole family.
So, now what? Well, GMRS is really taking off in my neck of the woods. Mid-Atlantic Virginia, eastern shore of Maryland, George Washington National Forest, etc. Several repeaters popping up too. It's the new CB radio and is far simpler to use than HAM- very practical for the whole family or inexperienced group to use. 22 channels (vs. frequencies and tuning--and yes, the 'channels' are actually frequencies but like a CB, they are numbered and thus easier to access and use) and are repeater capable. There are some channels shared with FRS but if you stick with GMRS, you can access up to 50W of power.
Locking the group on 'Channel 6', is much easier than ten rigs trying to tune in say 144.275MHz. Max power is 50W which makes GMRS very handy when out in the field/woods/beach and comms are spotty or non-existent. Add a repeater to the mix, either an existing one, or set up a portable one (using your licensed call sign) and you've created a very easy to use, semi-private, practical, and reliable communications network for your excursion. The weather alerts are a great feature especially when your on the coast, surf fishing, etc. Finally, even if you're all alone, having secondary or tertiary comms is like having a jack and shovel.
Anyway, I settled on the new Midland MXT575. I picked the version with the controls on the mic. That allows me to hide the transceiver elsewhere. For that, Mountains2Metal (M2M) makes a very cool and inexpensive mount that puts the transceiver or small amp, right above the glove box. Just have to love how Ford created all this space, nooks, and crannies for mounting stuff. And kudos to M2M for finding the space and making the mount! For me, it saved the under-the-seat, in the console, under-the-console, remove everything, debate. If you don't have plan for that empty cavity, use it. It couldn't be easier.
Step one, attach the radio mount to the M2M mount using supplied hardware. Tip, the 575 is the largest of Midland MicroMobiles (there's a little mod that needs made and we'll get to that). So, mount the radio with the 'M' or Midland as close to the front of the M2M mount as possible. Tip, get the Midland mic extension cable MXTA31 (you'll thank me later) and connect it once the radio is attached to the mount and before you install it in the horse:
I took the extra step of driving a self-tapping screw into the mount for extra stability. The other two connectors are bolts and lock washers.
Now the fun part. Remove your glove box and look for the two 'rails' and open space directly above. Make sure that mic extension cable is plugged in now! And forget about using that USB-C port. None of it will be accessible post-install. You figure out how to lay on your back, twisted half sideways with the door sill digging into your ribs.
Lift the rig into that free space:
It will look like this when set correctly, attach it with the two black torx screws that come with the M2M mount. I used one of the two screws as a ground point. Verified the ground and it looks like this (from the floor up, directly under the glove box. The coax and power wires are facing the firewall):
Notice from this angle, you don't even see the radio. I ran my hot wire and coax to the drivers side firewall. There is a very nice hole there with a removable cover (unless you have an manual trans because that's where the clutch cable runs).
You can also use one of the Aux wires just behind the passenger kick panel for power. But the pull to the battery is so easy, I didn't want to waste a switch position. The hot is fused and the fuse is accessible near the steering column and the radio has a time out feature. But, if you're not transmitting, battery drain is minimal, but a risk nonetheless.
Tip: Fully unwind/stretch out your coax and hot wire before pulling to the engine bay. Just makes life easier.
Hot to battery and coax to either side a-pillar (or wherever else you want to run the antenna). Mounting any antenna is slim pickens on a vehicle with no metal roof. Metal roof = ground plane. There are a lot of antenna mounting options. Hinge mounts, bumper mounts, spare tire rigs, etc. I like to keep things clean and simple. I used the M2M NMO mount which I installed over top my SDHQ a-pillar light mounts. Very simple and straight forward. I also chose to use the Midland MXTA25 Ghost Antenna with an NMO mount. Claims -3db gain and looks amazing on the bronco. Blends right in.
Slight digression. I've now bought 3 different a-pillar light mounts. The SDHQ are by far and away the best of the three. All three were good (Baja Designs and ZROADZ) but the build, finish, and 'lift' for the SDHQ are fantastic. It also move the lights out and away from the edge of the hood and gives ample room for the largest of cube lights. I'm running two XL80s which are some of the largest and they sit perfectly on the SDHQs. The SDHQs also align perfectly with M2M NMO mount.
A word on SWRs relative to GMRS. I haven't tested SWR yet. There's no trimming of the Ghost Antenna but I will and post the results. I suspect this Midland set up will yield decent SWR. If so, I'm done. If the readings are unacceptable, I'll switch to a 1/4 wave antenna, trim and test. I doubt that will be the case and if the results warrant it, I'll do a new thread. Generally, standard transceivers, unmodified coax, and appropriate antenna combos should be ok, but certainly not always. I just didn't want to turn this in to a thread on antenna theory. I'll test later this week and add if there's anything worth reporting.
So here's the catch. This is the mod you aren't going to like. But I swear, as a guy who like clean, neat, OEM-like installs, this one is a trim and forget kind of things. You have to notch the back of your glove box if you chose the MXT575 using the M2M mount. The heat sinks are bigger (50W) than their other rigs. No way around it. But, for the clean, neat, permanent kind of placement, I'd do it again and again. I highly recommend this mounting approach and once you make the trim, you don't see it and will forget it's there! I used a Dremel and cutting wheel. Marked a space and cut away.
Here's what the un-sanded notch looks like:
I cleaned it up and reinstalled it. Like I said, you can't even see it.
I also installed the Mountains2Metal MOLLE panel. Very nice product! Great for adding a small MOLLE bag to make up for the lack of driver accessible storage. Here is the mic extension tied in.
I just realized it took me more time to write this post than it did to mount and install the rig and wires...
Hope this helps someone. Up next, JCR winch plate and Warn Zeon 10-S.
SWRs. Interesting results tonight (12/06/22). The 575 only has two power modes (Low/High, 5W/50W respectively). I tested two antennas, the short wire that came with it and the Midland Ghost.
The SWRs with the wire antenna were terrible:
1.9 on average on the low power channels, 2.09 average on the high power. Unacceptable for an out-of-the-box configuration. To be fair, this could be influenced by any number of environmental/installation factors, not just Midland's tech.
When I switched to the Ghost antenna, things got a lot better. 1.01 average on the low power channels and <1.04 on high! With no other factors changed, those are exceptional results, all things considered.
Last word on this, power.... I'm disappointed. Midland calls this a 50W radio ("all values are approximate"). Low power was ok @4.4W on average. But, on high power, I didn't see an output of more than 42W. I would have liked to see something closer to 50W. Could +/-5W make a difference? YES. If I knew this would I have not bought the radio, no. I'm still very satisfied with the unit, antenna, install, etc. We'll see what Midland says, but I'm still a happy camper!
Can you send me a PM! I can't for the life of me get the MXT575 mounted with the Moutains2Metal bracket up there. I finally got it above the black metal rails, but can't get the bolt holes to align up! Thank you!!
