Most basic lift question ever?
PonyStable
JT
New York
2016 Mustang
Happy Thanksgiving 6G! I was wondering what sort of lift/leveling would be most suitable for a stock OB non-Sasquatch - no tire change, to give it a more aggressive look without going too crazy. Just enough that it's obvious that it's not stock. Be gentle.
NatureMan
United States
Rough country.
Brisco
Brad
2011 F350
Level kit= 1” spacer kit from RC or Zone. Very subtle, inexpensive. Check em out. GL
1975U15
2019 F-350 SD, 1975 Bronco
Yup…what Natureman said. Have 2” on non SAS OBX myself.
Gotta be honest tho. It’s not going to look aggressive with the stock Bridgestone Duellers and a lift. IMHO it’s gonna look even worse. The reason people lift is to clear more rubber for wheeling and look.
Techun
Pa
BD, 2.7, MIC, 4dr
Up higher with the same passenger tires will look...not good
PonyStable
PonyStable
JT
New York
2016 Mustang
So what rubber did you go with and were you able to offload the stock tires at reasonable value?
r21free
bob
michigan
2021 bronco badlands
my wifes bronco i went with 275/65/18 with no lift and tires look small ..
Ford Bronco Most basic lift question ever? bronco 10
1975U15
Mickey Thompson Baja Boss AT’s. Went from the stock 255’s to 295’s.
I get it. Replacing stock rubber to aftermarket is expensive. But if you’re going to lift it you should go with bigger tire. Otherwise, don’t lift it cuz you’re not going to get aggressive look you think. Go stock set up til you wear stock rubber then go with lift and bigger tires when new tires needed.
I’ve held on to my stock set for now, but if I need to sell I’m certain I could at some point.
Good luck.
ilbastarge
Northeast
Tesla X
I'm not a fan of levelling lifts because once you put some weight in the back then "your headlights are looking for aliens". I'd maybe go with a 1" or 2" regular lift. Keep the same factory rake.
YMMV
