- Oct 27, 2021
- 3
- 53
- 78
- Northern Utah
- Ford Bronco
- Base
UPDATE 03/31: Dealer was planning to replace the valve body and a solenoid, but then found metal debris. Now waiting for a new transmission to arrive for replacement. So far 21 days without use of the vehicle.
UPDATE 03/14: Vehicle is showing fault code P0756, which apparently means stuck in 3rd gear. Transmission requires disassembly for further diagnosis, which will take a minimum of three weeks. Will be towed to another dealer with a transmission tech. I'm fully expecting to not have the Basesquatch back for a month.
UPDATE 03/13: Picked up Bronco from dealer, who said the torque converter solenoid was sticking, which had happened before on new Broncos. Service advised take it on a road trip or drive more. Was able to get 130 miles in on a Saturday drive. Next morning, made it a couple of miles before engine failure again when in gear. Towed back to dealership. One common factor both days of engine failure was snow, so perhaps water is causing problems. Clearly a defect.
Unfortunate day yesterday as my two-week old 2023 2.3l Basesquatch with 157 miles on the odometer died and won't run longer than a few seconds upon start up. I went out for a milk run in the morning snow and had the vehicle in 4A for the first time. Was enjoying the ride, however as I pulled back into my driveway the engine started shaking, as error codes flashed and things went to hell.
At first I though it was a 4x4 issue, but I was able to get back into 2wd with no improvements. Engine starts and then immediately lugs and dies. Obviously not excited about a brand new vehicle having serious issues, but I'm sure it happens and I drew the short straw. At least I didn't break down on the road.
Ford Roadside Service showed up quickly and the truck is back at the dealer. Apparently only one tech at work this week, so it may be some time before they even get to it. Service manger on the phone thought it might be a voltage issue. Communication back from the dealership so far has not been great and no offers have been made for a loaner or other assistance.
Any advice is appreciated. I'll update when I hear more.
