NOW AVILABLE: Ford Bronco LED Cargo Light Module - PRE-ORDER
OracleLights
New Orleans, LA
www.oraclelights.com
FORUM-EXCLUSIVE GROUPBUY - PRE-ORDER BELOW!
The Ford Bronco is a great vehicle, but one area for improvement is the factory LED interior lighting in the cargo area. The existing lighting doesn't provide enough usable illumination for the rear cargo area. The Bronco is made for adventuring, but this lack of lighting makes accessing cargo at night difficult while on the trail, camping, or tailgating.
ORACLE Lighting has developed an integrated Cargo LED Light Module to easily add a bright LED light to the rear hatch cargo space and the area around the vehicle! This integrated light module uses the vehicle's existing 12V power source and simply replaces the factory wiper motor cover. Install is simple: just swap in the new cover using the included parts and plug the adapter into your rear accessory socket. The lights can easily be turned on and off with the flush switch located on the panel.
Features:
• ORACLE Part# 5887-001
• Installs in Factory Location
• Replaces Factory Wiper Motor Cover
• Mounts using Factory Hardware
• Illuminated Flush On/Off Switch
- Dual 5000K White LED Cargo Light
• Illuminates Cargo Space and Exterior
• Plug and Play installation
- 1 Year Replacement Warranty
• Designed and Engineered in the USA
MORE PHOTOS AND INFORMATION: https://www.oraclelights.com/products/ford-bronco-led-cargo-light-module
Ford Bronco NOW AVILABLE: Ford Bronco LED Cargo Light Module - PRE-ORDER 1629491320134
We are offering a 30-day forum-exclusive groupbuy for early adopters of this new innovation! These spots won't last long so grab yours now if you want in! (Please note that this is a pre-order for this product.) It's easy to get in on this:
  • Visit the product page for more information and resources.
  • Add the Cargo Light Module to your cart.
  • Check out using code BRONCOCARGO for 10% off with free USA shipping!
  • Done! Your order will be among the first to ship in April 2022!
GET YOUR SPOT NOW!
Normal Price: $149.95 + Shipping
Group Buy Price: $134.96 and FREE USA Shipping
Please note that the initial estimated ship date is currently April 2022 and is subject to change with notice.
Group buy code active until 3/11. Tentative ship date is April 2022 and is subject to change. Must enter code for group buy discount. Only these lights eligible for discount, not applicable for other products. No additional offers are eligible for this group buy. Free shipping offer is applicable to the continental US only.
Tarheel_Wes
Wesley
FJ
Features:
GET YOUR SPOT NOW!
This might have been asked in your original thread, but could this be controlled with an auxiliary switch? Like leave the oracle switch, and then use the aux to turn on?
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Yes, you can run a power wire from the Aux switch and connect it to the light bypassing the included switch and then turn on and off from your Aux (y)
Tarheel_Wes
Wesley
FJ
So, (correct me if I'm wrong) the Aux switches require the the engine to be on, or at least turn on ACC.....but is that true as well if you power the oracle with the 12v socket? Or does it always have power?
  • Like
Reactions: Cat
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Right, both require the vehicle to be in ACC not necessarily engine running.
  • Like
Reactions: Cat
OracleLights
OracleLights
New Orleans, LA
Tired of dim cargo lighting? The Ford Bronco is a great vehicle, but one area for improvement is the factory LED interior lighting in the cargo area. The existing lighting doesn't provide enough usable illumination for the rear cargo area. The Bronco is made for adventuring, but this lack of lighting makes accessing cargo at night difficult while on the trail, camping, or tailgating.
ORACLE Lighting has developed an integrated cargo light module to easily add a bright LED light to the rear hatch cargo space and the area around the vehicle!
Purchase today (3/17/23) and be entered to win a $100 Oracle Gift Card! Also use code FORUM10 for additional discounts!
ORACLE LIGHTING 2021-2022 FORD BRONCO LED CARGO LIGHT MODULE
Ford Bronco NOW AVILABLE: Ford Bronco LED Cargo Light Module - PRE-ORDER bronco-cargo-light-module-thumb_1024x1024
TheLawnDart
Austin
Las Cruces
FJ Cruiser, Subaru Forrester, Hyundai Palisade
Figured I would just tag onto this post. Hooked up the cargo light to the continuous power provided by the OEM trunk light. StickerFab eludes to doing this with their optional 12v attachment in THIS video, but it’s not necessary to get the attachment if you want continuous power. Just cut the end of the Oracle light, soldered a wire into the yellow wire in the OEM light, bought a $5 connector from O’Reillys, and ran in through the trim.
Ford Bronco NOW AVILABLE: Ford Bronco LED Cargo Light Module - PRE-ORDER 43553E93-8F8C-4BF3-B323-487428D867AE
Ford Bronco NOW AVILABLE: Ford Bronco LED Cargo Light Module - PRE-ORDER 69F8F447-B44E-4924-87A0-0FB03172B202
