NOW AVILABLE: : ORACLE Lighting: UNIVERSAL ILLUMINATED LED LETTERS
OracleLights
New Orleans, LA
www.oraclelights.com
Customize your vehicle with a vibrant new look with universal LED letter badges from ORACLE Lighting! These individual LED illuminated letters for cars are the perfect way to make your own marquee-style glowing vehicle badge. When turned on, the letters emit a soft edge-lit glow to make your custom badge stand out. Even when off, the sleek design of the letter housings gives a customized high-end appearance. The premium construction and overall styling deliver great value for an easy DIY illuminated badge. Simply choose the letters you need, and get ready to draw attention to your ride with a build-your-own glowing letter design!
Ford Bronco NOW AVILABLE: : ORACLE Lighting: UNIVERSAL ILLUMINATED LED LETTERS ORACLE letters
The LED lighting has a low draw, less than 0.1 Amp per letter. The overall size is approximately 3.75" wide x 1.4" tall and 0.5" thick. Installation is easy with the VHB double-stick adhesive. Wire the letters to a 12V source such as parking lights, ignition fuse, or a separate toggle switch. Please note that a hole may be required to route the wire, and each vehicle’s needs will be different. We recommend using our VHB Primer (ORACLE Part# 2082-504) to get the best bond with the mounting surface.
Available in Matte White or Matte Black Surface Finish and in all letters.
Ford Bronco NOW AVILABLE: : ORACLE Lighting: UNIVERSAL ILLUMINATED LED LETTERS 51974548055_57a9ec1ddf_o
helifino16
Ron
Mount Sinai, NY (Long Island)
Sending my order now.
#38490 - Now starts the wait. I'll 'Hang in there'.
broncomorrow
Indiana
2021 Ford Bronco First Edition
Any pictures available of the matte black letters on a bronco?
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
No, unfortunately matte black will not be availble until the end of the year.
privateer35
Seattle
Ford Bronco 2021
Do you have an isntall video?
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Are these street legal?
You would need to check the rules and regulations for your local jurisdiction to confirm if this complies with your state and local regs.
gentlemanbronco
Rick
ford fiesta 5.0
It probably depends on your state. From what I've researched as long as your lights aren't those blinding off road ones, or aren't red or blue, you should be fine. Red/blue isn't legal because its reserved for emergency vehicles.
604Bronco
British Columbia
www.bronco6g.com
604Bronco
British Columbia
www.bronco6g.com
That's a very Corporate, legal response. Appreciate it lol (just pulling your leg, I know you need to be careful with that).
