Offsets question
Broncolli
MD
'21 Back Diamond 4 door MIC
HI - are all the wheels you offer zero offset ? That means each one would poke out quite a bit on a standard Bronco model - non SASQ ?
Can you make a diagram with the Bronco and the amount of poke we can expect with zero offset and a base model for example ? Also is it safe to assume we will not need a lift if we have zero offset, or is there a way to predict the lift we will need ?.
PWillette
Parrie
Maine
No, they are not zero offset. Search is your friend, numerous threads out there on wheel offsets.
fifteen52
Fifteen52
Carson, CA
fifteen52.com
Coming Soon: 2021 Ford Bronco Outer Banks
Fair Question - Unfortunately we cannot provide a diagram or anything like that at this time, we ourselves haven't gotten ahold of a full sized Bronco long enough to make any additional measurements or information available. We will however, have wheels on multiple Bronco builds fairly soon and we plan on making sure we can provide imagery for multiple models.
For the question of lift, all depends on your tire size! We've seen 35 tires fit pretty comfortably, 37 seems to fit with the higher trims but there is possibly rubbing without a lift. We'll have to wait and see when we get ahold of one (or the two we're building here arrives) and then we can provide a bit more solid information.
Broncolli
Broncolli
MD
Great thank you - I hope you get your standard non-sas Bronco soon - as I would like to pick up wheels ASAP - I am a June 21st build.
You would think if Ford is using your stuff to demo - they would get you a Bronco...
fifteen52
Fifteen52
Carson, CA
fifteen52.com
We're grateful for being able to work with Ford on multiple builds so far, we'd love to get our hands on one for longer, but we can't imagine how many other companies are asking for the same thing. Hopefully though with many of these hitting the assembly line we can get the answers we need sooner rather then later.
HoosierDaddy
Good visual aide here will compare stock wheel/tire combo against your selection, if you input the info that way.
for reference:
standard Bronco wheels +55mm offset
Squatch wheels +30mm offset
soonerbronco
Noah
Knoxville Tennessee
1976 FJ40
I must have been under a rock recently. The tiresize tool is awesome. I have struggled with the offsets for months...... finally an easy way to compare!
Who’s your daddy? hoosierdaddy!
Thank you!
P52Ranch
Oklahoma
2DR 7MT Badlands, F150 Lightning, New Holland 4030
I saw the Overland concept Bronco at the Tulsa Auto show a couple of weeks ago. It has Fifteen 52 wheels on it with Sasquatch fender flares. I would assume those Fifteen 53 wheels are zero offset. Comparing these pictures of a Sasquatch to the Overland Concept. Looks like an inch plus more poke.
Ford Bronco Offsets question 1619576128295
Ford Bronco Offsets question 1619576572073
BigBronco1
Mamaroneck, NY
2018 Silverado, 2021 XC90
Do you plan to have offsets other than zero? Using a non-sasquatch Black Diamond if I swap the rims and keep the same tires, they're 2.2 inches further out. If I add the larger tires I want that moves to 2.7 inches, definitely a deal breaker.
June 14th build, hoping to install new wheels / tires day 1...would love the Traverse HD...but need the offset to be closer to +30!
HardenUp
Shane
Fort Mill, SC
First Edition 2021 Bronco
What are some of the negatives of having a negative offset wheel that pokes out an inch or 2?
HoosierDaddy
First and foremost , legality. Though it does not seem to be enforced much.
Second- damage from thrown debris because that debris is not being caught by the body or flares because the tire is out too far. I'm not talking about body damage to the Bronco, but to other vehicles/people.
As soon as people start getting hurt or their vehicles damaged and the lawsuits happen and awareness rises, there will be stronger enforcement.
The danger of thrown debris is why the tires must be covered to begin with, along with "mud flaps" on taller or more open tires also, like semi trailers.
Third It starts throwing the steering/suspension geometry off. Increased wear and tear on those parts. Rubbing on the turns. Handeling will be off...
HardenUp
Shane
Fort Mill, SC
Thanks for the response. I was worried about having the doors off with negative offsets and then being peppered with mud and debris.
