One brake already worn out?
Dullah
Honda Accord
Hey everyone, I have a ‘22 outer banks and just recently my back left tire has been making lots of noise while driving and it almost feels like im driving on a flat. I took a look at the tire and noticed that the metal inside seems a lot more worn out than the other wheels. I was wondering if anyone had a similar issue or had any idea what was going on. I plan on taking to the dealer tomorrow
Classic28
Brandon
Maryland
Nissan Titan
Might be a stuck caliper that has been applying the brakes causing the pads to wear out and dig into the rotor.
BikerDoc
HOWARD
Curious about the age of your 22 OB. I pick mine up this week.
mdfilip
New Hampshire
20 Shelby GT350, 22 Bronco BL, 29 Ford Roadster
Break or brakes?
How many miles are on the vehicle?
Hdscreens
Will
2dr Bronco Badlands
Hopefully, Ford dealer doesn’t say not covered by warranty 👎🏼
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
Might just be the pic quality but that disc looksvery grooved as well. Do they feel pitted?I would think if you had a locked or dragging caliper you wouldve smelled it and or felt the heat coming from that tire. Youre not a two foot driver are you? Ive seen pads wear quickly from people resting their foot on brake pedal. Pads will wear down to metal backing in no time pitting the disc. Im sure your not but ive seen it before.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Some type of pad failure. Looks like the rotor will need resurfaced or replaced if it’s not thick enough to resurface. Is it rough on both sides of the rotor or just the one side? Could be a sticking caliper or just a defective pad.
RobBob22
Rob
Georgia
2018 F250 SuperDuty
Maybe jammed caliper slide? That rotor looks grooved for sure. With only 8K miles I hope they goodwill warranty that for you. If the caliper itself needs replacing that should be covered for sure. Generally rear breaks are smaller and less powerful, it's no unheard of to not notice the added drag. The metal on metal sound may be obvious.
New rotor on that side and pads on the rear, and maybe a fluid change.
Dullah
Honda Accord
I appreciate it, I’ll update yall tomorrow when I reach out to the dealer
SuperDave150
Albuquerque, NM
Ford F-150, Ford Edge
Easy diagnosis & fix once they get in there. Unusual, but not the end of the world.
Deleted member 3063
Guest
if your brake has been dragging your mileage would be shitty.
