Outerbanks ground clearance ?
mdepll
mike
toronto
sorento
1. WhAt will be ground clearance with those 18” standard wheels ?
2. will it suffer off tossing because 18 inches instead of 17?
Advertisement
mdepll
mike
toronto
sorento
  • Thread starter
  • Thread Starter
  • #3
1. What’s ground clearance on outer banks
2. Will OB off-roading performance suffer because of it’s 18 vs 17 inch wheels ?
pan-y-cerveza
Manitoba
Ranger
I've been off-tossed more times than I can count with 18s. I'd go 17 for this reason alone.
mdepll
mike
toronto
sorento
  • Thread starter
  • Thread Starter
  • #6
TomH
CT
Ridgeline
Should be the same ground cleanance. They are both 32” tires. The 17s are 225/75s, and the 18s are 255/70s. Ground cleanance will be the same. The only hiccup may be the running boards that are standard on the OBX
mdepll
mike
toronto
sorento
  • Thread starter
  • Thread Starter
  • #9
What do you mean only hiccup is running boards ??
TomH
CT
Ridgeline
The running boards may be lower than the rockers resulting in less ground clearance. Can’t tell by the pictures
Techun
Brianfirsta
Pa
Fiesta st
The 18s will give a “better ride” on the highway, the 17s will be better for off roading.
Maybe turn-in feeling, the 18s will be worse for comfort.
Advertisement
Advertisement
