Fuzion2Bronco
Asher
New England
Base Sasquatch
This is amazing. It looks like a desert tan / brownish / greenish / military color. If that is the case (which I hope it is) that will be the color I choose. So indecisive between A51 and CG colors.
[/QUOTE]
May be its just Unpainted Frame? ;)
MrJoe
Joe
Southern Maryland
'73 Bronco (sold), '99 Ram, '08 Explorer, '16 CMax
I hope they do a better job of priming/painting than they did with the EB's...
B33001
Brandon
Virginia Beach, VA / Outer Banks, NC
2018 raptor
Pics by Dennis C.
Area 51
new color?
My grandfather worked at the Ford truck plant in our area for 41 years he told me that the first 50 to 100 production models have blemishes and they use them for paint testing before any metallic flake or clearcoat
Spooled
Republic of Texas
I would wager these were used in the paint validation process. I would also wager the "new" color is just a primer paint layer.
Lowcountry Bronco
William
South Carolina Lowcountry
Ok, enough green/tan/cactus grey talk ... no one excited about the VB??? Been bouncing between white/AB/Silver wanting to see a VB that's not someone's paintshop rendition.
Kuze
Ali
Bay Area, CA
G63
[/QUOTE]
I really hope its not. LOL... If this turns out to be true, I will put my order without wanting to see A51 CG colors in person. ?‍♂
mC.242
2021 Big Bend 4dr (sold)
I have a sneaking suspicion that's bare metal or primer and not a new color.
And wow, that many tan fans? Not a fan of the tan on the Toyota trucks.
Lab00Rat
MS
2022 BL 2-Door, 2021 Ford Ranger
After some investigating, I believe I was able to narrow down the approximate location of these Bronco bodies based on where the light is hitting the Area 51 Bronco and its position relative to the blue water tower. Here is a satellite image of the Wayne Assembly Plant where I have marked where I believe these Bronco bodies are sitting. See if you can find something I did not.
Just because I can't leave well enough alone...
I do not think these are from the PAINT plant and color checks. These are outside the assemble plant for final build.
1. Plant layout and the location of the Photo.
Ford Bronco Painted 2021 Bronco Body Frames Captured! Mystery / New Color Spotted 1599580002612
2. The plant layout relative to Stamping, Body, and Final Assembly.
Ford Bronco Painted 2021 Bronco Body Frames Captured! Mystery / New Color Spotted 1599580041574
No idea why they are there, or where Cyber Orange is in this mix, but they are outside the final assembly plant, not the paint plant.
T Copp
Travis
KC
Bronco, Mercedes GLB
That's some detective work right there.
GotGOAT
Tim
PA
Dodge Ram
O lord if there is a desert tan...
If there is a desert tan it jumps to my #1.
I can relive my Overseas desert running Fiascos, oops I mean adventures.
Monster79
E
Alabama
15'Stang, 07'F150, 23',96',93',79'Bronco
Lol, it is still a toss up between CG, VB, and just black lol I gotta see em in person.
GotGOAT
Tim
PA
Dodge Ram
The sheet metal on the building looks like ‘putty’ or a ‘pumice’ color, a slightly tannish gray, specially in contrast to the carbonized gray and silver bodies. The anomaly looks like desert tan to me.
Building color analysis...check.
Utilizing pumice in Bronco talk...check.
This guy needs to go have a discussion with the a Bronco Color Selection Team! It is obvious you put more analyt thought into colors then anyone assigned to the team.
