Agreed! And here is a link to the thread/docMake sure to check that the fuses are fully seated, the 3 fuse box bolts are snug, and your battery cables are tight before you leave the dealer lot... Otherwise you may not make it home.
I think the battery is 10mm, and the fuse box bolts are 7 mm or 8mm
This the standard now? I thought this was in the past. Doubt anyone is really gonna climb under the hood with a small socket set and start checking things.Make sure to check that the fuses are fully seated, the 3 fuse box bolts are snug, and your battery cables are tight before you leave the dealer lot... Otherwise you may not make it home.
It's optional for sure. Only trying to help out a fellow Bronco owner.This the standard now? I thought this was in the past. Doubt anyone is really gonna climb under the hood with a small socket set and start checking things.
Thank you I sure willMake sure to check that the fuses are fully seated, the 3 fuse box bolts are snug, and your battery cables are tight before you leave the dealer lot... Otherwise you may not make it home.
Well I picked mine up two months ago, in the rain, and I still climbed all up on it, in it, and under it checking all kinds of things before I drove it off the lot. I was a wet rat by the time I was done.This the standard now? I thought this was in the past. Doubt anyone is really gonna climb under the hood with a small socket set and start checking things.
I guess if you’re that paranoid after spending hours reading forums.Well I picked mine up two months ago, in the rain, and I still climbed all up on it, in it, and under it checking all kinds of things before I drove it off the lot. I was a wet rat by the time I was done.
99% of my fuses under the hood were not seated. The fuse box has taken four rounds of snugging back up until they finally have stayed snug. I had to zip tie the water hose because it was almost touching the pulley, And I verified that the wires above the axle were snapped up properly so they wouldn't rub through on the 100+ mile trip home.
All the things that would prevent me from getting it home.
And that was just the checklist "at dealer pickup"
