Plastic To Modular Bumper What It Takes To Install.
SGXIX
I picked up a modular bumper off marketplace yesterday and insalled it today. I noticed it almost fit withou cutting iff the base tow hooks. I lossened the bracket so the modular bumper fit, added some washers to the front bolt of the tow hook and a rubber spacer to the intercooler bracket and tightened it all back and seems fine. Anyone see any issues with this fix that im missing?
Trying to do same install. Did you encounter any issues by leaving the base tow hooks in there?
Rygator
Ryan
SOUTH FLORIDA
2022 Bronco, 1986 bronco.
I made it work with the spacers. I cut the plastic skid plated to make them fit. If I can find the steel skid plates ill cut of the hooks.
SGXIX
What product did you use to fill the sensor holes?
Kayderade
Cayden
Missoula
Just wanted to confirm for anyone switching from the capable to modular bumper, the sensors and sensor grommets aren’t the same. I knew I’d have to cut off some of the notches on my grommets so they’d go into the holes on the mod bumper, but I didn’t realize what the issue was for the sensors, themselves, until after I started the swap.
With the capable bumper, the sensors you get have the plugs stick straight out the back of them instead of at a 90 degree angle like the other versions. This is fine for the middle two sensors, but the ones on the end get pushed through the front of the bumper when you install the metal brace that goes behind them. Ford sells these other sensors for around $200, so I decided to modify the plugs going into the back of the sensors I had to get me enough clearance. I was able to cut about 0.25” off the plugs and it was just enough to get everything reinstalled correctly.
Hey there! I am planning on swapping from the capable bumper on my badlands to a mod bumper like you. I would also like to reuse my sensors rather than buy from ford for $200. You indicated that you trimmed .25” of the plugs to make it work. Can you tell me exactly what you cut off? Was it the female end (plug) or the male end (sensor) and how did you cut it? Cheers!
OuterJersey
Honda, Toyota,VW, Lexus, Triumph, Honda MC
@Wildtrak84 thanks for all the great info. I may have time this weekend to finally get this going. I purchased Oracle foglight pods to add in while I'm doing this. Going from the plastic to the MOD bumper.....is there only one connection for sensors and foglight? So I need to determine the foglight wires in the bundle and add a jumper of off those? Is that correct? thank you!
cr117
PNW
Bronco, EV6
It was the plug that's attached to the wiring harness. I was able to trim off everything below the red line in the first picture. I then used some liquid electrical tape to make sure it was all sealed up and protected.
Ford Bronco Plastic To Modular Bumper What It Takes To Install. IMG_8512
Ford Bronco Plastic To Modular Bumper What It Takes To Install. IMG_8510
Ford Bronco Plastic To Modular Bumper What It Takes To Install. IMG_8513
OuterJersey
Okay I put the MOD bumper back together, I think everything is in the right place. There are 2 longer torx head bolts not sure where they go. If anyone can help. I also have an extra sensor bracket and cover that is up for grabs. Just let me know if you need that.
Ford Bronco Plastic To Modular Bumper What It Takes To Install. IMG_7332
Squatched
Wil
Maryland
89 Ford Bronco
I’m assuming no reprogram is needed if changing sensors. My plan is to pull 2 of the 90 ones from the rear bumper and put the straight ones back there were I can. I’m going from capable to mod
I swapped from capabale to mod a few weeks ago. After seeing this post I tried this and it has worked just fine. It was easy enough to sneak my hand into the rear corners to take out the sensors. I have taken it to busy parking lots and full parking garages no issues.
Earlybroncoboy
Wagner
Pa
22Bronco,76bronco,73bronco,06F250,96F250,97F350
Yep worked flawlessly for me as well glad I could help
OuterJersey
All done. Used oracle fogs in it. If you use plug in adapters be aware that the colors are reversed for + and -. So the small harness I bought were reversed to the oracle lights when I connected them.
Ford Bronco Plastic To Modular Bumper What It Takes To Install. IMG_7380
Mujenpwr
I’m planning the change of my front capable to a modular. When you used 2 of the rear bumper 90 degree sensors. Which sensors did you use From rear? Outer ones? And does it matter which rear side goes to which front Corner?
Earlybroncoboy
Wagner
Pa
If I remember correctly I used the outer ones. Didn’t matter what position I installed them
Mujenpwr
Ok great thank you for the quick response.
alexraw
alex
South Florida
Bronco / Toyota FJ Cruiser
Hey,
I have the lux package with this same bumper and I was wondering did you follow the video OP mentioned without having to do anything else or did the steps OP layout work fine?
I’m just wondering if I need to order any additional sensors or if my current sensors / harness are fine with the modular bumper. I didn’t hear OP mention which package he currently has in the video.
Pdshepherd
Patrick
Gulf Breeze, FL
None. Wife's Kia is my part time wheels
Hey,
The one thing that is easy to miss is rhe bezels on the parking sensors are angled a certain way for each one. And the ones from the plastic bumper won’t do in without cutting a piece off. They are cheap to get though.
