- Rohan
- Feb 28, 2022
- 9
- 74
- 25
- Birmingham, AL & Bowling Green, KY
- 2023 Ford Bronco BL SAS LUX 2.7
- Badlands
i recently was gifted a set of used rock slide engineering step sliders from a family friend who traded their bronco in. Upon picking them up I purchased some new magnets and door sensors, along with other miscellaneous nuts and bolts that the dealer had lost upon removal of the steps from his bronco.
Today, I was able to start the installation of the steps to my own bronco. The wiring and mounting of the drivers side step went as expected, taking time to line up the pinch welds and ensuring brackets were lined up with their holes.
upon moving to mount the passenger steps, I ran into some trouble. I have quadruple checked that all of the brackets are in the correct spot, made sure to loosen all of the bracket hardware to aide in sliding in the step to the pinch welds, and used a jack to lift the step into place. However, no matter what I do, it seemes the step refuses to sit into place. Iāve scratched the hell out of the pinch weld paint trying over and over again.
Iām thinking one of the brackets must be bent or broken, because thereās no way that it shouldnāt slide in after this many attempts. So I might have to call RSE to order some new brackets I guess.
Does anyone thatās installed these steps have any advice? Anyone run into any similar trouble? If it isnāt broken brackets, should I call my local customs shop? I feel terrible doing that considering I was able to finish off all of the door sensors, wiring, and drivers side step. Any help/advice would be appreciated!!
