Alanh
Alan
Nashville TN
Minivan
Hello Bronco family,
Here are some photos of a new product we have been working on here at AGS Off-road. Introducing the Bronco Air-gate! We are looking to get some opinions from our customers. Would anyone be interested in a product like the one pictured below or would you rather have the mount built into a modular tailgate support? The version pictured below could be available for purchase much sooner than the modular tailgate support version. Both versions are still being tested and need your help to figure out which one to focus on more. Product pictured below is a proto-type and is not built to the same quality final production parts will be.
Thank you,
AGS Off-road
I WANT THIS. Of course that is dependent on Ford scheduling, producing, and delivering my 2021 reserved Bronco. HURRY UP FORD, I have so much stuff to buy.
BostonGuy
Boston
Jetta
This may seem like a crazy question but how would one of these compressors work for blowing up other items? Like does it have tips I can use for tubes?
Sorry I have kids and this is all new.
Bikeric
Tulsa
1984 4Runner (For Sale)
I don't usually get excited about products, BUT THIS IS PERFECT!! Sign me up and take my money.
West1
DM
Atlanta
Bronco Base with OBX wheels
Thank you,
AGS Off-road
Hats off to you on that one, that was very creative and ingenious.
Aman
Aman
Northern NJ
I only found water resistant not water proof, which probably means you'll be driving around with a very expensive rusted up paper weight within 2 Years.
You posted water proof, but I couldn't find that, I'm not surprised, the internet is full of non answers.
But unless/ until someone can back this up, I'll let others spend their money.
Very few products are considered "waterproof". Manufacturers generally refer to their products as water resistant and will often offer an IP rating. That being said, I do not know the IP rating of the ARB Twin, but it can be submerged in water, so nothing to worry about having it mounted under the spare.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
ARB states that the brushless fan that cools the electronics, motors and cylinder heads has an Ingress Protection rating of IP55.
Below is a chart that explains what that rating means...
Ford Bronco Pre-order live!! A new innovative ARB Twin Compressor mount (within spare tire mount) IP Ratings Guide
86Isuzu
Buffalo, NY
89 Bronco II, 03 Ranger Level II, 2022 Bronco
This is just an air compressor. You can attach any kind of fitting to the end. Blow up tires, pool floats, run small air tools, spray paint your house...
DriveAllNight
Dan
N.J.
One Very Cool Ride
Cool ... getting my learn on :LOL::cool:
MNbronco
RC
SE MN
2021 F150 Tremor, 2021 Bronco sport
this is high pressure, low volume; you would be better served to carry a portable inflater (low pressure, high volume) for inflatables otherwise it will take forever to fill
Tstarks
Trevor
Washington
Ram 2500
I like it... Could be some challenges, depending on the wheel you have
Ingridthehorrible
FL
2005 Chevy 2500HD, 2008 Buell 1125R, 98 Buell S1W
Novel mounting solution, suspect they will have heat issues due to the way it's mounted and the design of the actual tire carrier limiting cooling air flow. Hopefully they will preform actual real world testing of at least 15 minutes run time airing up tires with at least 100 to 110 degrees F ambient outside temp.
Due to the design of the mount the cooling air for the compressor appears to be blowing the cooling air up into a dead air space in the spare tire mount and compounding the issue the air intakes are in this same area.
These ARB twins cylinder heads can exceed 250 degrees F while running with ambient temps of 94 F.
Here's an IR scan from a couple months ago that I took while doing some temperature testing or the ARB Twin compressor
Ford Bronco Pre-order live!! A new innovative ARB Twin Compressor mount (within spare tire mount) 1662605269377
Doesn't anyone know what type of material the Ford spare tire mount is made of.
DriveAllNight
Dan
N.J.
One Very Cool Ride
Sounds to me if we air up long enough we can break out the hotdogs and have a weenie roast.
See, it's not all bad 😁
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
That’s a nice chart. Ty
BroncoSarge
Jeffrey
Most mount it under the hood. Cant imagine that has better airflow.
