Procal Tune versions changes
hiro_pro
Stuart
Lky-043080!
2026 4dr Bronco Badlands 2.7t
Following. I have a 2026 badlands 2.7 and was not able to turn off auto start/stop. Followed all the instructions but the module and code didn’t line up.
RoverDude
RoverDude
Maryland
2021 Bronco (First Edition)
Could you list List what module information is installed. It be helpful for tracking purposes for when this change happen.
Moe-Jave
SE AZ
2022 Bronco Badlands (2dr/manual); 2023 Jeep Gladiator Mojave
Can you post what the software versions of the modules are currently.
It'll be helpful to know and what version that was removed
Yes, I agree and will get to that. Note: even “back then” (about a year ago), it was known that current ProCal software removed the rev matching feature (and had been true for some time already). There was plenty of related discussion about auto stop/start, too. My recollection is that MY2023/2024 and newer could not have auto stop/start disabled any longer (via FORSCAN or ProCal, but third-party solutions may work). I don’t know if that remains broadly true, but can report it remains true on my Bronco re: auto stop/start being disabled.
For now, I’ll say that it was the latest version available about six months ago. I ran the hardware display for months but after convincing myself it worked and was stable, I packed it away.
I only run 91+ octane (best generally available in AZ) and run Top Tier for their detergents. I also have the Roush intake (and stock exhaust). No codes, no issues…just notably better power / smoothness down low where I really needed it. Slightly better fuel efficiency, all else being equal. An average around 18MPG lately with a mix of highway and dirt roads (running 35s and stock 4.7 gears).
Note, I don’t plan to install every release. Unless I have an issue or a compelling feature comes out, I don’t plan to upgrade. I’m curious if everyone else sees it this way too…
Wyld2dr
2023 2 dr Bronco; 2016 Audi A7 tdi
What kind of boost psi are you seeing? From zero with full throttle and downshifts on the freeway?
Moe-Jave
SE AZ
Boost pressure varies based on a lot of factors, right? I’ll just say that it is 3-5 PSI on average more than stock based on my recollection. This is a mild tune and frankly doesn’t feel that much stronger to me up top. The calibration is smoother, however, for my driving conditions. Partial throttle conditions are especially better.
So for the same day/conditions, where stock would have hit 18 PSI, I might see 21 or 22 PSI briefly. I think it is worth noting that other tuning changes are at play here too — fuel, torque management thresholds, timing, so on. I notice the overall change but it isn’t dramatic (compared to my various other tuned cars…WRX, Fiesta ST, F150 3.5EB, Audi S4/S5, etc.).
Does that track for you with your mods?
As noted, I really only noticed consistent low end changes. It feels smoother and stronger down low where I think the 2.3 needs the help.
Wyld2dr
I didn't notice you had the 2.3, mine's the 2.7.
I was seeing 19 - 21 over the winter. I'm seeing 15 psi on WOT from a stop and 17ish on freeway downshifts. I'm going to clear the tune, install the updates, reinstall and relearn. I'm hoping that fixes things a bit.
I run 91, have one step colder spark plugs plus every bolt-on.
JL8jeff
Ewing, NJ
I'm guessing the mods that help airflow result in lower boost numbers because you're already pushing a lot more air. I have similar mods and I think I've seen around 18 for boost but I haven't checked recently.
