Raptor beadlocks or not beadlocks
bajabronco57
Nor Cal
4Runner
None of us need anything as over the top as a Raptor either, though. I chose to spend $2k on the bead locks simply for looks. Aftermarket Warthog wheels will be limited and more expensive than Ford’s offer.
I'm not talking about looks. The bead locks look nice. No one needs any Bronco so that is kind of a lame argument imo. You can get by with some 1990 Honda. That isn't the point and it wasn't what OP was inquiring about. OP asked if they needed them for rock crawling, they didn't ask about looks. Having been rock crawling if you aren't sure if you need them for what you're doing you probably aren't on extreme enough terrain to need them.
F1rstEdition
Johnny
Wake Forest, NC
13 Overland Sequoia - 21 FE Bronco - 13 200 Series
I was told the "standard" non beadlock ready wheels are not even available and that is holding up my Raptor build. Anyone else hear that?
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
I ordered a Bronco Raptor last Friday and had to select the optional wheels to get my order accepted.
Drttrac
Troy
Mesa, AZ
2010 Range Rover Sport SC Autobiography
My dealer rep called a few weeks ago asking if I wanted to upgrade to the forged wheels to expedite my order as they had ran out of the standard wheel. Not worth the $2k in my opinion as the wheels were the first and only thing I was going to swap out.
350vudu
350vudu
Cleveland, OH
2017 Shelby GT350, 2019 Ducati V4S Corse
This was my position as well. I actually already have new wheels and tires sitting in my garage but I made the switch in hopes of getting scheduled sooner and pray I can sell them to recoup some of that cost back.
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
Realize that is you run beadlocks (not just beadlock capable) you need to re-torque all those little bolts around the rim. My off road shop suggests monthly some do it quarterly.
i mostly enjoy high speed desert off roading so I am passing on beadlocks. But the maintenance is something to consider. Granted, they is a lot of 4x4 prep one should do prior to an off road trip, and some people enjoy this aspect.
UniBroncorn
2022 Bronco Raptor
My 2022 Braptor has the beadlock capable aluminum wheels. 2023 Braptor no longer has these particular wheels as an option. The 2023 has the regular and Beadlock capable forged wheels. Wondering if the wheels i have on the 2022 have been discontinued or constrained.
Ford Bronco Raptor beadlocks or not beadlocks Screenshot_20230114-014421_Gallery
gryphon1231
dj
Miami FL
na
Its beadlocks That really important if not for rock crawling? Is it worthy the $2k?
The real question you should be asking is if they are worth the constant maintenance and attention running bead locks requires.
swamp2
Wouldn't a bit of low strength (blue) loctite solve any Beadlock bolt maintenance issues?
wanna1
Andrew
I asked the same question and was told that I needed to use anti-seize on the bolts.
swamp2
As contradictory as it might seem loctite does provide some antisieze properties. It isolates the male and female threads with a chemical film which helps against any electrochemical effects that could contribute to seizing. It also prevents movement which can lead to galling and then seizing.
If it's a well known issue that beadlock bolts come loose and/or need anti-sieze, I would personally go with low or medium strength loctite.
chtucker
Kirkland, WA
FJ Cruiser
Over a year running real beadlocks no air lost and nothing needing to be torqued (although I do check every few months) I was met out with a digital torque wrench and Ted-Gel
Ford Bronco Raptor beadlocks or not beadlocks 5CF1B329-B51F-4A49-8819-749795DC6866
swamp2
Some reasonably hard wheeling I assume?
Can you clarify the bold part (typo maybe)?
chtucker
Kirkland, WA
FJ Cruiser
Darn tiny keyboards on the phone
I was meticulous with a digital torque wrench and Tef-Gel
Digital torque wrench that read down low https://www.acdelco-tools.com/index.php?route=product/product&path=61_87&product_id=131
And Tef-Gel anti seize
https://www.tefgel.com/contain.php?param=tefgel_infor
I did 4 rounds of torquing 5lb, 10lb, 15lb and 20lb in a star pattern.
Mind you my wheels are aftermarket.
Did I need them, Nope, was a I scared of doing them Yep. Would I do it again, Yep. I hate "faux beadlocks" just for the looks. It was either nothing or beadlocks. I looked into Hutchinson Rock Monsters, but at the time they wanted $7500 for a custom set.
I was able to get a very specific offset and hub centric wheels without hub bore adapters. I have about 18mm of offset. I didn't want poke.
