Raptor button not working
Derrick
Derrick
Ontario, Canada
2023 Bronco Raptor, 2010 Audi R8 V10
Last few days notice the "R" button not working and did some research and some say to wait a day and check , but still not working. Found same issue on F150 Raptor forms and they say to disconnect the negative battery terminal for 10 to 15 minutes. Disconnected mine for an hour while I was doing other things then re attached and now is working. I didn't see any updates so not sure why this happens and first time since I picked it up 10 months ago.
swamp2
I posted on this very topic not too long ago here on the forum. The solution is indeed battery disconnect.
Derrick
Derrick
Derrick
Ontario, Canada
Thanks, I did a quick search before posting but nothing popped up. Maybe I am using an incorrect phrase or something.
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
Search functions on forums generally suck..
Next time, ask google.. but add *insert forum name here* at the end of the question or whatever. You'll find it works much better.
swamp2
Google-fu tip of the day to supplement/clarify this. This is generically applicable and I use it constantly. Try this syntax:
your search terms site:website.com
For example:
R button not working site:bronco6g.com
results in the first hit as my post.
Thank me later ;-)
Kjbeggs
Kelly
2019 Ford Ranger
I find most times, just a standard Google search for any Bronco related question leads me to B6G for the answer anyway!
PA BRaptor
Kevin
Western PA
Ford F350
I've had mine for just over 1 year and about one month after purchasing it Raptor button quit working. I disconnected the battery and left it for 20-30 min. After reconnecting it all was fine, it worked. It never happened again.
