- Thread starter
- #1
Decided I can use one. Need recommendations for one and it must be rattle free if it exists. Thanks.
That’s a nice design. I like the wood extension.
The Trailgater from Outback Adventure Products. No drill and no rattle.
Agree, easy no issue, no-drill installation, still rattle free.
I just bought that same one yesterday. I figured the hardware would be junk, but thanks for letting us know just how bad it is.I bought some cheap one on Amazon and just went to hardware store and replaced all the crappy bolts that comes with it with better grade bolts. Mine never rattles and is super secure now with the bolts I used. Here is the one I got and I've used it several trips over the last year and still works perfect. Just please don't trust the bolts on any of these cheap ones as they are crap and will break with any weight.
https://www.amazon.com/gp/aw/d/B0B1CTCVY6?psc=1&ref=ppx_pop_mob_b_asin_title
If you are only doing light weight stuff it may be fine but I didn't want to trust it so the $15 spent on better grade made in USA bolts was worth it to me. I just took all the bolts needed from the kit and drive to my local hardware store and got all new bolts and washers. I've had heavy lunch boxes and jugs of water and it doesn't budge at allI just bought that same one yesterday. I figured the hardware would be junk, but thanks for letting us know just how bad it is.
Same. I bought this. https://a.co/d/eByKcVrMabett. No drill and rattle free. Even comes with some foam gasketing to further prevent rattle.
You left out the part where it sits a solid foot lower. I have this folding table.Just throwing this out there if you are not married to having a mounted one.
*individual setup time takes around 2 minutes per use.
- 1/3 the cost of the cheapest mounted one.
- Can put next to the tailgate OR anywhere else.
- If you are cooking no concern regarding heat or smoke.
- Packs up small.
- Does not rattle.
- Can use without your Bronco.
- No drilling or install time.*
So do I and great point! ALPS and others make options that are higher and lower. Just an alt suggestion that a small, packable table is another great option that is flexible. Especially if you actually use your hitch, don't want your bronco stinking like a cookout, and being confined to the tailgate for usage.You left out the part where it sits a solid foot lower. I have this folding table.
Any thoughts on this over the GooseGear one?
