Rear side window leaks
Tiresmoke410
Ohio
22 bronco, 16 F250, 66 F250, 68 mustang
took my 2dr in for a couple warrranty items I have been sitting on until it was worth the trip.
One of the items was leaking rear side glass. I didn’t find it until 9 months into ownership since it normally is parked inside and I don’t sit in the back. Once found I also noticed it seems the windows were loose along the top edge. Now it’s fixed under warranty and I wish I had done this sooner.
the door no longer sounds like a 70s tin can import when closing it. Apparently those loose rear windows rattled more than I thought just from door closing. Wind noise is nearly zero. It is like I have a hard top. Which I do. Before it was about at noisy as one would expect from a bad soft top. Go figure. If water can leak so can air!
have to say I’m in love with this truck all over again. It is relaxing quiet at 55 mph. And I don’t cringe every time I close a door.
WheresMyBronco
Los Angeles
2023 Badlands
Both of my rear windows in the MIC leak slightly during heavy rain, this might just convince me to get it fixed/serviced.
CarGuy
New Jersey
2023 Ford Bronco
My 2-door also leaks near the rear window. Was in for service last week and claimed to have fixed it, but still leaking. Back to the dealer.
Ford Bronco Rear side window leaks IMG_1784
kcjaman79
Jeremy
KC MO
F150,F250,Mustang, 2 Miatas, Bronco
Mine is in the shop now w/3100 miles for the same reason. Passenger side leak in two places. They are removing the window then cleaning and re-applying the bead to seat the window back in.
Ford Bronco Rear side window leaks leak
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good afternoon. Go ahead and send us a private message with your VIN and the name and location of your Ford dealer, and I’ll look into this leak concern. Thanks!
Ford Motor Company
Dearborn
Hello, John. Would you please send over a private message with your VIN and dealer info so I can look into this leak concern further?
Realdieu
Same here.
Having been a quality manager at Webasto, it’s amazing how little these leak. That’s another story though…
Ford Bronco Rear side window leaks IMG_1977
Ford Bronco Rear side window leaks IMG_1976
Coralhead
Floyds Knobs, IN
'23 Bronco Base Squatch
I fixed mine using flowable silicone via a syringe to leaking areas.
Tiresmoke410
Ohio
After posting this I saw ford is recalling for quarter windows that will fall out. Glad I beat the rush on that one!
Mine was not included in the bin range but I know I didn’t have 100% adhesion to the frame. I had about a 4” section on each window that was visibly loose from the top.
hope everyone else gets there issues resolved too.
Ford Motor Company
Dearborn
Same here.
Hi there! I can look into your Bronco's leak concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
SeaVee
Greg
Va Beach
2002 2500 Suburban, 77 Bronco, 2001 Cherokee
Can I join the club?
Ford Bronco Rear side window leaks IMG_0569
Ford Bronco Rear side window leaks IMG_0568
SeaVee
Greg
Va Beach
Whoops - sorry for the duplicate pics
Ford Motor Company
Dearborn
Hi there, Greg. These rear window leak concerns doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end. To send a private message, just click on our username and select "Start Conversation".
