Rear tailgate noises
Rick mueller
Appleton
2021 bronco
Anyone having a noise similar to a coffee can with nuts and bolts rattling when going over bumps,
A simple fix is installing neoprene ( plastic)
Thin washers between the tailgate and the hinges.
I was almost to the point of selling the truck because of the irritating noise.
This simple fix cured all with a trip go Ace Hardware for the washers
dangelo27
Boston, MA
2022 Bronco Big Bend
Can you post pictures? This has been driving me crazy as well
Rick mueller
Appleton
2021 bronco
I cant see the washers as they are installed, behind the hinge and between the tailgate.
So photos not available.
When you install, I used packaging tape, to tape the rear door to the body to avoid movement.
Then I used painters tape, not bigger than the hinge to hold washers to the door when installing hinge bolts, to avoid washers falling durning the install.
