Rattle and Popping Noises from B pillar
Tataman
Todd
Gilbert
2005 Chevy suburban
I have what sounds like the same rattle, and I have a soft top. I have not been able to get the latches right above the front seats to align properly, but the rattle definitely sounds passenger. It sounds like it’s coming further to the back. I only really notice when I am off reading or hitting rough road. I was thinking it was the soft top lowering mechanism hitting the back support bar, but I was not to see any thing that was loose when riding in the back seat.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this on my end.
Pepperenavich
2018 F150 Fx4
I have a similar rattle in the B pillar. For me it is coming from where the seat belt loops through the clip that rotates. If I push on that area the rattle instantly stops. I plan on putting something there to fill up the space. I had to something similar on my F150.
Rendo
Rene
Chevrolet Silverado 1500
That's horrible! I've had somewhat the same in my Silverado that came from the dash board. I removed the entire unit and still couldn't locate it. Turns out, it was the windshield wiper fluid housing that was loose, haha.
I had that same marble rattling sound coming form the B pillar in the passenger area on the driver side. I also thought something had dropped into the frame (small acorn from a live oak tree I have shading my driveway) and was stuck in there rattling around. I noticed it after I had taken off the hardtop one afternoon to install the Bimini sunshade.
Couldn't find the source of the noise on my own so I took it in to the dealership when I started getting a high pitch sound coming from the front tire area as well. Turned out the high pitch sound was a small rock that had gotten wedged between the rotor and the shield. They removed it and that sound went away.
Well it took them a while to figure out what to do about the rattling from B pillar. After test-driving it to verify, they said the driver side roof section alignment pin on the B pillar was making contact with the alignment pin bracket causing the rattling sound. They wound up installing a small piece of rubber grommet on the pin and that took care of the sound. Hope this helps anyone trying to figure out what to do about that rattling and popping sound they may be getting.
BigTex
Duke
Plano
2008 Mini CooperS Convertible, 2022 F150 Platinum
Does anyone else have a rattle and popping noise that comes from the passenger B Pillar?
I can't determine where it's coming from exactly, but it's near the B Pillar and seatbelt housing area.
I drove with the seatbelt tugged and it still has a hard plastic to plastic popping noises on small bumps.
Yes, I have the noise. Check out this video and go to the 5:40 mark where he talks about the noise. Mine is the exact same.
I have self diagnosed it to the back left latch on the front driver’s side panel (right by your left ear when driving). put your hand on this latch while driving and push up…..sound should go away. Not sure how this was manufacturered, but my guess is that there is a plate sandwiched between the inner and outer shell of that panel. The inner plate is where the sound is coming from probably due to an air gap. Maybe not enough adhesive was used? I don’t know, either way, put your hand on that latch while driving and push up and see if it goes away.
BigTex
Duke
Plano
Ksjrb03
Tx
F250
Have you done the condom fix for the alignment pins? It’s almost always the pins.
BigTex
Duke
Plano
Ford Bronco Rattle and Popping Noises from B pillar E87163D3-BC0C-4E87-973F-E9D7F5749507
Well I’ll be…….WOW! FIXED….not with a condom but with some tape. I’ll replace with black electrical tape so it’s not visible. Problem Fixed. THANKS!
Ksjrb03
Tx
F250
All your pins will be taped eventually. Been there done that lol. It’s unbearable when you have multiple going off in full stereo 😂
BigTex
Duke
Plano
Ford, are you listening?
BigTex
Duke
Plano
Looks like a long term fix could be rubber grommets for all the alignment pin holes? Please advise.
bronco_quig
Kieron
Canada
2021 Bronco, 2020 AMG E53, 1978 Z-28, 1970 C-10
I have a very similar problem, the passenger side B pillar rattle - but on a 4-door soft-top. Is this a known issue? It’s been too cold here to try and troubleshoot, but I am about to go insane with the noise, so I will take it to the dealer - but would be nice to know if there is an internal bulletin to cite?
Thanks!
amccue90
Andrew
Illinois
2021 Badlands
Let us with the soft tops know if they @Ford Motor Company helps you out
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Ford Bronco Rattle and Popping Noises from B pillar 567085D6-E5DC-4CCD-B2C7-AED465939B42
I used rubber wheel bearing covers (trailer bearings) and just trimmed out the center section and rolled it over the pin. Seems to work like a charm in case anyone it trying to come up with an alternate solution. Hopefully MIC 2.0 resolves the issue when I get it replaced this spring.
Tataman
Todd
Gilbert
2005 Chevy suburban
I was very impressed that FMC reached out on my post. My expectations were way too high. Long story short, I was passed over from one rep to another and was ultimately told "the issue is not able to be diagnosed without scheduling a visit to my dealer". I am not here to rain on the parade, but that was a complete waste of everyone's time. Could have saved everyone's time and just said from the get go to schedule a trip to the dealership.
In full disclosure, I was finally able to latch down my soft top with latches in the middle and will go out again to see if that addresses the issue. I am planning to be go off-roading the weekend of Jan 22nd, so should allow me to see how the soft-top performs. If nothing else, I can record a video, as I am not sure how a service department could recreate the rattle in a city environment. I have no issues when I am on city roads...
