Replace Sasquatch with Method 703 Offset question.
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
I don't what white, can I just rotate them, or should I search for a set without white lettering?
If you dont want white then just look for "BSW", "Black Side Wall", "RBL" Or "Raised Black Lettering"
derichio02
Bo
Southern California
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
www.instagram.com
Ford Bronco Badlands
I will one day swap to the 7XX series Methods. I love the bead grip tech, but also love my Double black 305's. Post pics of your rig when you mount!
For sure :) Right now I am on the fence between 703 and 705 / BFG KO2 and MT Baja Boss AT / Poke or No poke.
#thefirstworldproblems :D
Raptor911
Raptor911
Broadlands, VA
I assume you are wanting 315/70/17?
KO2 are C-rated in this size and 9 pounds lighter.
MT Baja Boss are E-rated (much rougher) and 9 pounds heavier.
Get the K02s
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
www.instagram.com
Get the K02s
I am thinking about 35/12.5/17 for both. Leaning toward KO2, but still thinking...
Raptor911
Raptor911
Broadlands, VA
not sure what D2 means but these tires are rated at C, D or E. Nitto even has some tires rated at F. C is the softest and tends to be the lightest while E are the heaviest and a much tougher tire. They are also very heavy
Too rough? What about D2? MT is D2
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
www.instagram.com
Checked other sources, Baja is E.
broncorik
I just kept my Goodyears and plan to use them until they wear out. I figured I would not get all that much for them used, and the plus side is that they are the lightest of the bunch. I like Nittos but they are over 70 pounds, so K02s for me after I grow weary of the Goodyears. Now I just need to sell my SAS wheels...but it seems everyone else is doing the same.
Raptor911
Raptor911
Broadlands, VA
SAS wheels are heavy as hell … like 35 pounds. I had a second set that I removed the tires and TPMS from so I weighed the wheels
NJRoadkill
South Jersey
www.instagram.com
22 Bronco Badlands 2.3l Manual
MT Boss A/T
The 315 is an E
the 35x12.5 is a D
Only the Jeep and Ford performance versions of the KO2 are C
the others are E.
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
www.instagram.com
MT Boss A/T
The 315 is an E
the 35x12.5 is a D
the others are E.
Yep. Actually, I ordered 35x12.5 Baja Boss A/T. Coming tomorrow :)
NJRoadkill
South Jersey
www.instagram.com
please post a picture when you get them installed. I’m down to the same two choices as well, which is the only reason I knew the specs off the top of my head.. 😂
