Replace spacer or bumper between spare tire and tailgate for 0 offset wheels
monkeyboy1317
Paul
Douglas, GA
'89 EB Bronco, '13 Tacoma, '10 Suburban
I have a '22 Wildtrak and replaced the factory Sasquatch wheels with new 0 offset wheels. The spare was no longer touching the spacer or bumper between the tire and tailgate. Enough space for a spider to make a home... The fix for this is ordering a new spacer, Ford Part #M2DZ-1A401-A, you will need two (2) as they are sold individually. Simply take your spare off, remove the old spacer and replace it with the new one. There is only one plastic screw holding it to the tailgate. Took about 15 minutes for the whole job. *Add extra 2 minutes for arachnid extraction.
Ford Bronco Replace spacer or bumper between spare tire and tailgate for 0 offset wheels 20230818_093549[1]
Ford Bronco Replace spacer or bumper between spare tire and tailgate for 0 offset wheels 20230818_093613[1]
Ford Bronco Replace spacer or bumper between spare tire and tailgate for 0 offset wheels 20230818_095550[1]
Ford Bronco Replace spacer or bumper between spare tire and tailgate for 0 offset wheels 20230818_093221[1]
Ford Bronco Replace spacer or bumper between spare tire and tailgate for 0 offset wheels 20230818_095725[1]
Ford Bronco Replace spacer or bumper between spare tire and tailgate for 0 offset wheels 20230818_095915[1]
Ford Bronco Replace spacer or bumper between spare tire and tailgate for 0 offset wheels 20230818_100503[1]
Ford Bronco Replace spacer or bumper between spare tire and tailgate for 0 offset wheels 20230818_100511[1]
monkeyboy1317
monkeyboy1317
Paul
Douglas, GA
I have no idea why it shows each picture twice, sorry.
Sardine
2022 Elantra N - 6 speed & 2023 Badlands
I need to do this. So this should fit my 17x8.5 0 offset and 315/70/17 tires right? I have a NON sasquatch badlands that I got bigger wheels and tires for. Is the tire carrier any different on a sasquatch?
There's about a 1.5" gap between my current bumper and the tire. Are those longer bumpers 1.5" longer? Hard to tell from the pic.
Gtrekker
Gary
I have a '22 Wildtrak and replaced the factory Sasquatch wheels with new 0 offset wheels. The spare was no longer touching the spacer or bumper between the tire and tailgate. Enough space for a spider to make a home... The fix for this is ordering a new spacer, Ford Part #M2DZ-1A401-A, you will need two (2). Simply take your spare off, remove the old spacer and replace it with the new one. There is only one plastic screw holding it to the tailgate. Took about 15 minutes for the whole job. *Add extra 2 minutes for arachnid extraction.
Nicely done! I have been searching for a similar spacer to add or replace the factory ones. I've done the fit test and plan to add a 1.5" wheel spacer to push the spare out so I can wash behind the spare.
Your post gave me another search avenue. Thanks!!!
L&Ebronco
Oklahoma
94 bronco, 18 F250
Is one meant for Sasquatch and the other for non Sasquatch?
  • Like
Reactions: 0ne
monkeyboy1317
monkeyboy1317
Paul
Douglas, GA
I think it is about an inch longer.
monkeyboy1317
monkeyboy1317
Paul
Douglas, GA
There were 3 different lengths listed. I just went with the longest one. I think it was an inch or so longer than my original.
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
Why do you need two? That is confusing. Your post says (2), what do you mean?
monkeyboy1317
monkeyboy1317
Paul
Douglas, GA
They are sold individually. You have 2 on your tailgate.
monkeyboy1317
monkeyboy1317
Paul
Douglas, GA
I don't have all the answers. Hope this helps.
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White & 22' JLURD
Awesome, thanks for sharing
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
Thanks, I needed this for my 0 offset wheels..
I had a similar problem had about a one inch gap. I purchased black rubber furniture pads that have self stick on them. They fit perfectly both space wise and in diameter. Solved the problem without $ or a lot of work.
