Bought some GPCA quick release bolts with the tie down points. These look to be good quality and not excessively expensive like some others I've seen. During install one of the original factory bolts was hard to remove. The other 7 could be removed by hand after a few turns to loosen them. Took a look at the bolt once I got it out and looks like they cross threaded it or somehow the threads got galled during the install. Thought about grabbing a tap to clean up the threads but instead took one of the undamaged bolts and ran it in. Tightened it a few turns and then backed out going deeper each time until it was seated all the way. When I pulled it out I took a look at it and the bolt was undamaged. Then ran in the new GPCA bolt with no problem. The new bolts tighten up and remove easy without needing tools. The handles are metal not plastic. I really like the added tie downs with these bolts.
