- First Name
- Randy
- Joined
- Sep 11, 2020
- Threads
- 0
- Messages
- 636
- Reaction score
- 1,121
- Location
- Austin, Texas
- Vehicle(s)
- Bronco Big Bend. FJ Cruiser
- Your Bronco Model
- Big Bend
Them damn 56k dialup modems! Someone needs to invent an upgrade.
Unfortunately direction from FordPass phone line was to take it to a dealer.I had simular problem on mine,it was trying to activate on the wrong account,a call to fordpass got it all squared up.
For the first few days I was actively checking each time that connected apps, vehicle WiFi, and everything was working before trying to activate.Have you checked to make sure it is on? Seems unlikely, but I'd double check to make sure it didn't get turned off somehow.
I don't have a Bronco, so I can't direct you towards to menu needed. But I've seen online that it can be turned on and off, so it's possible.
We tried multiple times at the dealer with no luck. I could have had them figure it out there, but really wanted to wrap up purchasing the vehicle and drive it home.Whats odd about this is dealers are suppose to do this before leaving the dealer.
I'm using a Galaxy Note20 Ultra on Android 11, FordPass app is a fresh install and up to date on 3.27.0 from the Google Play store. I checked for updates on the head unit a couple of times and the vehicle reported back it was up to date each time.What phone? Current firmware? We had a '21 F150 this happened to recently and it was software. Had to reinstall software from the server. First thing though is making sure the phone is compatible and has the latest update.
I think I found the exact post you're talking about. I wasn't able to find a region setting on the truck from what I could see, but I asked the service advisor to check the region on the vehicle.sounds like a region lock. read some other places, like machE forum where the dealer resets TCU, does a flash and basically wastes some time... where the real issue is the car came off the line and region locked to Germany.
So suggest that they quickly look at region setting on your car and make sure its USA first. Then of course a free car wash and gas top off.
keep us posted!
Best of luck, I had no success over the phone.Having the exact same problem, waiting on a call back from a Ford engineer after spending over an hour with support.
@DudeBronco good news, so far everything looks resolved for me! Service department disconnected the battery for 10 minutes, did a "reprogram" on the TCU, then pulled me over to activate the vehicle and it immediately prompted and activation was successful. Plaintext for reference:@mjopp Did you hear anything back from the dealer today? I'm waiting on your outcome before I take mine in...Thanks!
Thanks for this! Mine is having the same issue and I'll mention this solution to my dealer when I take it in tomorrow.@DudeBronco good news, so far everything looks resolved for me! Service department disconnected the battery for 10 minutes, did a "reprogram" on the TCU, then pulled me over to activate the vehicle and it immediately prompted and activation was successful. Plaintext for reference:
"Verify customer concern, connect FDRS found no DTCs related to customers concern, connect to TPS run Oasis check for TSBs SSMs open WS manual go to symptom chart . Disconnect 12V battery for 10 minutes. Reprogram TCU module retest Ford Pass, OK after repair concern no longer present".
Less than 10 minutes after I activated I had 42k more FordPass points added to my account and put in a repair order for a set of door bags.
Hope that helps you out.
Guess this is what Ill do tomorrow. Tried every other possbile solution i could find. Sitll cant activate. Hopefully dealer can fix it.@DudeBronco good news, so far everything looks resolved for me! Service department disconnected the battery for 10 minutes, did a "reprogram" on the TCU, then pulled me over to activate the vehicle and it immediately prompted and activation was successful. Plaintext for reference:
Thank you for this. I did exactly this and resolved the issue.Had this issue with my new Bronco I picked up a couple days ago. Went through a lot of troubleshooting steps and finally got it to work. Being an engineer, I am pretty tenacious and tried a lot of things before getting it to function , including calling ford pass and working with one of their techs.
My Problem was that the modem didn't seem to be activating or turning on in the car, even after a Ford Pass reset or master reset. Instead of trying to find the modem and pulling the cable out of it, I just disconnected the battery for 10 minutes and opened the doors and pushed start to discharge all the power.
After 10 minutes I reconnected the positive terminal on the battery and went through the Ford Pass app process of adding the car cx again. This time it worked!
I successfully tested the Ford Pass Functionalities and am happy with the results. It's also worth noting that the disconnection of the battery didn't reset my settings / preferences.
The only fix to this is resetting your modem by disconnecting it from power. You can do this either by pulling fuse #20 on drivers side fuse panel ( which I suggest getting a fuse remover/tweezer because mini fuse is pretty hard to come out ) or by disconnecting the battery for 5 minutes.So, the solution was literally to unplug it, wait, and plug it back in?....![]()
