- Adam
- Aug 30, 2021
- 355
- 4,382
- 5,844
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
We're seeing more and more people asking for reverse kits. I believe we stock more reverse kits then anybody else out there so we've gone over a few of our kits to help you guys decide on the right kit for your truck...
UNDER BUMPER
Baja Designs
https://www.4x4truckleds.com/2021-ford-bronco-reverse-light-kit-w-baja-designs/
Kits start at $299. Completely plug and play. Lights come on automatically in reverse but you can also trigger them from an upfitter switch. The kit includes our brackets which alllow you to
mount the lights as high up under the bumper or as low under the bumper as you want.
Also this kit includes our new "plug and play" installation method. We provide an in-line taillight connection so you don't have to cut anything or splice anything. It plugs in-line with the factory tail harness. Nice and easy!
Diode Dynamics
https://www.4x4truckleds.com/2021-ford-bronco-reverse-light-kit-w-diode-dynamics/
Kits start at $249. Completely plug and play. Lights come on automatically in reverse but you can also trigger them from an upfitter switch. The kit includes our brackets which alllow you to mount the lights as high up under the bumper or as low under the bumper as you want.
Diode Dynamics (Trailer Connection)
https://www.4x4truckleds.com/dual-l...-diode-dynamics-lights-7-pin-trailer-harness/
This is similar to our other Diode Dynamics kit (same mounting method) however instead of using a harness to run up to your upfitter and tail light, we're plugging in-line with the trailer harness. So it's even easier to install. The lights feature a red back-light via this method which tur on when your headlights are on. Lights turn on automatically in reverse.
SPARE TIRE MOUNTED
Baja Designs
https://www.4x4truckleds.com/baja-designs-reverse-kit-for-2021-ford-bronco/
Kits start at $344.95. This kit mounts to your existing spare tire. It includes a bracket that lets you mount the lights and the wiring harness. It's controlled from an upfitter switch
Diode Dynamics
https://www.4x4truckleds.com/diode-dynamics-stage-series-reverse-light-kit-for-2021-ford-bronco/
Similar to the Baja Designs kit, this kit mounts to the spare tire using included hardware. But it'll also activate automatically when going in reverse. You can also use a switch as well to turn them on/off
All of these kits are in stock at our warehouse so order on our site.
UNDER BUMPER
Baja Designs
Diode Dynamics
SPARE TIRE MOUNTED
Baja Designs
Diode Dynamics
