- Brian
- Sep 14, 2023
- 13
- 1,247
- 1,805
- Central CA
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Big Bend
So my Big Bend didn't come with anything, and not knowing any better, I had just got a cheap Chinesium nerf bar and threw on the thing to start with. Its your standard oval side step
With the height of the Bronco (35" with 2.5" lift), they never really worked as I wanted. I'm a bit older and have lost some spring in my step, my wife has issues getting in too, and my inlaws can't get in the truck at all (not necessarily a bad thing, mind you...) - the nerf bar wasn't low enough to really help as a step.
I'm not a serious wheeler, but do like to go up in the mountains from time to time, and I've come to realize two things:
The nerf bar cuts into my ground clearance - I've only banged it a couple of times so far, but it's just a matter of time (I have ruined quite a few on F150's just out and about in the field on stumps and such)
But
It's not low enough to be a comfortable step
So basically, I'd like to replace it with a rock rail that doesn't impede ground clearance significantly and still protects the body. And I'd like a removable stirrup step - something that drops down and makes it comfortable to get in and out, but it halfway easy to pull off in the field when I go off road.
Most steps I see are more or less even with the rock rail. I've seen a few that drop like a real stirrup step, but most seem to be roughly at the same level as the rock rail, which would be no different or maybe even worse for getting into the Bronco than my existing nerf bar.
The Ford OEM hoop step is an option I suppose, but it doesn't attach to the real rock rail. It isn't clear if that comes with the rail (it does say the rail isn't a real rock rail - no idea how durable that thing would be), or if it requires a not-included OEM rail to mount to.
I was looking at the RC SR2 - but that doesn't look like you can really pull the step out in the field without dropping the entire bar down. It's also aluminum so I don't know that it would hold up very well if it did take a hit.
The RSE ones look nice, but wow are they pricey.
IAG has removable steps for the OEM rail, but they aren't stirrup steps and I'd still need the OEM rail.
Any other suggestions? I don't wheel hard, so the rock rail doesn't necessarily need to be bulletproof, but something that would take a hit or two without being disposable would be nice. Throwing a step stool in the back end is not an option (we already do that for the inlaws if we have to).
But
