- Michael
- Aug 2, 2021
- 1
- 9
- 7
- California
- 2019 Silverado Trail Boss
- Badlands
I just picked up this kit In the 3” Osram option:
https://www.roughcountry.com/bronco...-71045c.html?find=2021-ford-bronco-4wd-784415
My question on the wiring is, am I able to utilize an up fitter switch with these? If so, what’s the best way to go about it? I can’t find info on how many amps they draw, so I wasn’t sure if cutting out the fuse and relay and everything was a good idea or not? I was hoping I could just use the connector sections then fuse both positives together then use a connector to attach to an up fitter wire then connect both negative wires together and ground them. Is that safe to do with this kit or do you think their amps are higher and I gotta keep all that stuff intact?
I’m pretty novice with wiring so I appreciate any help!
here’s a diagram of the wire kit they send
