Sasquatch Level and 37s - “Before” Measurements Needed Please
BroncoZ13
Georgetown, TX
2021 Bronco Badlands 4 Door
Hi yall, small favor to ask
can someone with a stock height 4 door Sasquatch measure their height from center hub/wheel to bottom of fender flare (front and back)?
just installed the Bilstein 6100s and completely forgot to get measurements of “before” to check level. I still have a 1.5” rake so questioning how much the front end actually came up.
I used position #5 of 6 on the spring clip for the 6100s, and instructions/specs claim that it should raise the front 2.0” and rear 0.9”, but I don’t think it lifted that much.
Current front hub to fender 23.25”
Current rear hub to fender 24.75”
thank you in advance!
Ford Bronco Sasquatch Level and 37s - “Before” Measurements Needed Please 735DA8D9-4139-4766-8D72-FA9BF0927020
Ford Bronco Sasquatch Level and 37s - “Before” Measurements Needed Please B4F3CD4B-F84F-4328-9A2E-12B06B03064F
Ford Bronco Sasquatch Level and 37s - “Before” Measurements Needed Please 637EF64C-19BD-42B1-A921-D48901FD2D1C
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
I tossed my measurements but I know I got 1.5" at the front at clip setting #4. I left the the rear at the bottom (stock) clip setting and the fenders are now perfectly level front and rear. Mine is a stock Sasquatch BL that had 1.5" of rake to start with (actually on side was only 1 3/8" low in front) and now both sides are perfectly level and the rears did not move at all.
BroncoZ13
BroncoZ13
Georgetown, TX
Thanks for the feedback on your lift, and I might just go up to local Ford dealer and try to find a Bronco to measure to compare.
rtaylor
R
ID
19Raptor, 22Bronco
Factory ride height specs. Sasquatch = Adrenaline Rush.
Ford Bronco Sasquatch Level and 37s - “Before” Measurements Needed Please 1664854000180
Ford Bronco Sasquatch Level and 37s - “Before” Measurements Needed Please 1664854059124
Ford Bronco Sasquatch Level and 37s - “Before” Measurements Needed Please 1664854113688
Gtrekker
Gary
NJ
Cant help you much (SAS, High pkg), didnt measure then....
Maybe y ok y can pull or cypher the measurements from the dimensions sheets when the came out.
Your stance looks like a good!!!👍👍
Gtrekker
Gary
NJ
BroncoZ13
BroncoZ13
Georgetown, TX
Ford Bronco Sasquatch Level and 37s - “Before” Measurements Needed Please 20221001_143331
Thanks for providing, but not sure I can compare these specs with my Bronco since I have 37s now which increase ground clearance vs factory tires.
Really need a center of hub to fender measurement as that would be best/easiest way to confirm. Thank you though for sending
rtaylor
R
ID
19Raptor, 22Bronco
Note that tire size doesn't affect the ride height spec. It is only measuring the suspension.
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak
Front 21.75, rear 23.25, this is with 2.7 motor, heavier than 2.3 which may affect front slightly
BroncoZ13
BroncoZ13
Georgetown, TX
Thanks Copperhorse, this is great!
Mine has the 2.7 also, so should be same.
So on position #5 for the 6100s it lifted the front 1.5” and rear 1.5”hence the rake 🤦‍♂️
was supposed to make level, but oh well, it looks great now on 37s.
thanks everyone!
Denny3297
Dennis
Wisconsin
Acadia, Ranger, Fusion, E450 motorhome, Focus
thanks everyone!
Any rub with the 37s?
BroncoZ13
BroncoZ13
Georgetown, TX
Not with the BFG 37x12.50 which run a little small. I also tried the Yoko Geolander 003 in the same size and they barely touched rear crash bar mount at full lock, so went with the BFG instead.
I plan to install this max tire kit that removes the crash bar mounts since the Sasquatch package didn’t use them, and opens up plenty of space for 37s with a level, so shouldn’t rub when wheeling.
https://jksmfg.com/collections/ford-bronco-2021/products/ford-bronco-max-tire-clearance-kit
