- Trey
- Sep 23, 2020
- 7
- 146
- 488
- Frederick, CO
- 2021 Ford Bronco
- Badlands
Hey all,
Frustrating one here and looking for some pointers.
I purchased 5 silver sasquatch wheel beauty rings that someone took off their rig, and I had them powdercoated black. Plan is to use the black ones daily, then swap on the original silver ones so I can beat them against rocks this summer.
I had no trouble breaking the Threadlocker loose on 4 of the 5 wheels, and got the black rings swapped over.
When I came to the driver front however, I came across a single bolt that would only turn a few times and then would stop turning. It felt mechanically stuck like it was cross threaded. I had applied enough torque to start tearing up the T45 both head, so I stopped before it stripped out all the way.
I ordered a replacement bolt ahead of time, and went to the dealer today to have them look at what was going on.
Their mechanic was able to get the bolt out by applying heat, and swapped my black ring on. Great!
…except he didn’t put the ring on where the notch lined up with the valve stem.
It was late in the day at that point - no big deal, now that the bolt was removed and replaced with the new one,shouldn’t have an issue just like I didn’t have an issue on the other 65 bolts right?
wrong. There are now TWO bolts on that wheel that feel like they won’t come out.
help me out here guys, because I don’t want to keep hitting this with my purse.
what heat source should I use to warm these two up myself without wrecking the powdercoated ring or painted bolt?
