Sasquatch wheels on non Sasquatch outer banks
ENassif
Eugene
West Des Moines, Iowa
Chevy Volt
Just pulled the trigger on some Sasquatch wheels and tires. Want to confirm that they will fit on the outer banks. Might end up doing a lift too.
Thanks in advance!
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
Thanks in advance!
They will fit. You will have to remove the crash bars.
If your doing anything off-road, you're going to want to do a lift.
Aviboy97
Connecticut
Thanks in advance!
I know this is an older thread, but have you installed the SAS wheels on your OBX? I have an OBX and considering the same.
ENassif
Eugene
Chevy Volt
Yes! I did. Took out the crash bars (waiting on the new ones from 4wp) but they fit perfectly.
Aviboy97
Connecticut
Sweet!
can you post a pic?
really wondering what the poke looks like from theside profile.
Jsullivan
Jay
2018 Explorer, 2016 F350 Diesel, 2013 Explorer
Thanks in advance!
The rims will fit fine. You can go with 285/70R17 tires and not have to remove the crash bars.
  • Like
Reactions: LCW
rgalvinmi
Bob
2022 Ford Bronco 2 Door, 2022 Ford Maverick Hybrid
I have a 2 door base, I removed the front wheel crash bars (both front and rear) and installed the sasquatch wheels and tires. No lift. Here she is! Before and after pics.
Ford Bronco Sasquatch wheels on non Sasquatch outer banks broncoEGbase1
Ford Bronco Sasquatch wheels on non Sasquatch outer banks broncoeg35naked
Deleted member 49144
Guest
What is the offset on these? I'm considering putting these on my outer banks with stock painted fenders and want to get an idea of how far they are going to stick out. I have stock badlands rims and tires on it now and the edge comes just under the fender. I dont mind a tiny bit of poke but i want to keep the vast majority of the tread underneath the fender.
AKBronc49
Russ
Anchorage, Alaska
I have a Sasquatch Bronco that I added painted obx flares to (I run them in summer) so I have a couple photos. I don't like a lot if poke, I'd say this is about perfect.
Ford Bronco Sasquatch wheels on non Sasquatch outer banks 20230708_182842
Ford Bronco Sasquatch wheels on non Sasquatch outer banks 20230618_102441
  • Like
Reactions: LCW
Guest
wow that looks great. Do you think the mud guards are a big necessity, as far as protecting the sides? I have the factory hoop steps that I installed, seems they would offer some protection.
AKBronc49
Russ
Anchorage, Alaska
For me 1000%. I added power steps and lost the protection of my stock step boards. I put PPF on the lower 6" of the doors. The rear flares are getting hammered though, will need a repaint and PPF before next summer. I already had the passenger side front door repainted from a rock chip..im pretty meticulous.
I run my Sasquatch flares in the winter when I swap to my snow tires.
Guest
yeah I see that youā€™ve got gravel there, I heard that those tires are just rock throwers. Iā€™m in Fl and I donā€™t think Iā€™d have as much trouble with gravel, but Iā€™d probably still do ppf. Iā€™d hate to get rock chips as well, Iā€™m just as meticulous.
AKBronc49
Russ
Anchorage, Alaska
Yeah I'm in Alaska, a lot of gravel.
HoosierDaddy
Indiana
Yep, I just did several miles of gravel road recently and was surprised how scarred up the front of the rear flares is now ... luckily, non-painted Badlands flares (non-Squatch)
