"Service procedure interrupted" while using ForScan
Cloak
Nate
2022 Ford Bronco Big Bend 4 Door
I recently got my 2022 Bronco BB lifted with 37" tires. I found the thread of how to configure everything via ForScan but when I go to clear the PCM, I get the error pictured below (Service procedure has been interrupted). Has anyone else experienced this? One video I watched, the guy never cleared his PCM after he recalibrated the tire size, not sure if it was edited out though. I went for a drive and no error codes come up on my dash and the speedo seems correct, but I'd rather have everything cleared if possible to avoid any chance of a dealership questioning me if I need to go in for service or something.
Ford Bronco "Service procedure interrupted" while using ForScan Capture1.PNG
Ford Bronco "Service procedure interrupted" while using ForScan Capture2.PNG
Ducati1098
You already have a lift with 37ā€™s. Personally as a technician, seeing that code wouldnā€™t make me question anything. I wouldnā€™t even worry about it.
The only other way I know of clearing this out would be by using the Ford scan tool (FDRS) to relearn module data. Unfortunately that doesnā€™t really help you. Maybe shoot an email to forscan and ask them for help. Theyā€™re usually pretty good about working through things like this.
ā€˜21OBX
Ken
90Bronco19
2022 bronco outer banks
