Found these on Amazon Seven Sparta 2 Aluminium Grab handles (Click Here) $69. Preferred these over the para-cord solutions.
Easy to install for the front seats only. Remove the two bolts, put into place and re-install the bolts.
These are well-made and solid. Fit and finish is great. Easy to hold onto.
The one drawback is that they are close to the sound deadening material on a hardtop. If you have large fingers or wear big rings this could make for a very tight or impossible grab. I have smaller fingers so this works for me and my wife (see image below). I see no issue at all with a top removed. I cannot speak on the spacing for a soft-top or if you do not have the sound deadening material. If someone has these builds please add to the discussion.
I recommend - with the above caveat.
