adrencg
Bronco Badlands Sport
Thanks. So why don’t they come with the module? These takeoffs or what?
My guess is that it was cannibalized for parts for another Bronco headlight assembly. I'm going to try the Ford dealer to see if they can get one for me.
nicknasty
Nick
Ohio
Ford Bronco
I've been looking to do this exact thing with my big bend, so I'm curious how this works out for you. This website looks like it has the headlights with and without the module, but also sell the module by itself. here's the link if you're interested. I'm thinking of going the ebay route myself and finding a module if it doesn't come with since it's significantly cheaper than buying each headlight from oem parts.
https://ford.oempartsonline.com/oem...vJnk9MjAyMSZ0PXdpbGR0cmFrJmU9Mi03bC12Ni1nYXM=
Usdmmark
New Port Richey, Florida
GMC Canyon
seems like I've seen some people swapping to the signature lights and they are dim, is there a fix for this or is there a part number to stay away from? also the auto leveling will that be an issue for base/bigbend?
Djd7
Northeast
BD
There is no auto leveling OEM Bronco headlight sig. or not
they are all leveled by a manual adjustment
Ford Bronco Signature LED headlights installed on Black Diamond - plug and play with no fault codes E24B8418-2880-4618-9449-B7D1B9C7E2E0
gringoloco
Germany
2023 2-Door
Anyone who has done this swap, what's the DRL function? Full, bright white during the day?
MudMonsterRacin
PA
2003 Mach 1, 2016 F150
Curious... What about just replacing the bulbs in the rear to LED? Since the front lights on ALL models are LED, then there shouldn't be any hyper-flash in the rear after bulbs are switched. Switching them to LED bulbs would at least give you a brighter and cleaner light look.
I haven't seen anyone do it without resistors. My f150 hyper-flashed on the dash but was regular outside. Hopefully the bronco is the same. I don't wanna add a resistor.
JeffL
Massachusetts
2019 Challenger Hellcat Redeye / 2023 Base SAS
bumping an old thread but this is a no right, the halo DRL doesn't work? you have to run the parking lights to get the halo things to work?
JeffL
Massachusetts
Plug and play on my Big Bend, full bright white halo and bar during the day
thank you! just so i understand fully the day time running lights are just the halo and bar? and come on when you put it in drive? not the headlight like the base? reason i ask is this guy:
had to turn the parking lights on for them to light up.
beardymcstash
MY23 Bronco 4dr Black Diamond
i've also been curious about this as well. i saw the same video a while ago when i was trying to figure out if it was something i wanted to add to my mods spreadsheet.
gringoloco
Germany
2023 2-Door
I think that video is the reason why I came in here asking the question back in November. I decided to buy a new set of Ford lights, plugged them in, and everything works as it should.
Only difference I can tell is that the halo turns off when the turn indicator is flashing; I don’t think the factory installed signature lights do this. Doesn’t bother me.
I can’t speak to the in park vs drive function as mine is a 7MT.
