- First Name
- Brian
- Joined
- Sep 14, 2023
- Threads
- 15
- Messages
- 1,392
- Reaction score
- 2,055
- Location
- Central CA
- Vehicle(s)
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Your Bronco Model
- Big Bend
I can't recall if the wire is there or not. There should be a "dummy enclosure" with a "dummy amp" installed in the passenger cargo side quarter panel. The speaker should drop right into the enclosure and the amp screw right onto the side.The fusion amp is strictly for the sub, correct? Is all of the wiring and power already there in the dummy set up? Just plug and play?
Getting at the sub takes a bit more effort than getting at any of the other speakers, but it's not horrible. Even if you wanted to run new wire, it's only 2 more easy trim pieces you pull off (the plastic lower door trim) from what you would already do for the front kick panel.
Here's a video that was done by a forum member here, I think he did this very same thing, he's also doing all the speakers and an amp - so it would be a good watch.
https://www.bronco6g.com/forum/threads/2021-22-6-speaker-audio-upgrades.89182/#post-2165714
