Rocky Road Outfitters is working on a lift as well as other parts for the Bronco.
Rocky Road Outfitters Bronco Parts
Do the modular quarter panels not open the possibility of adding wheel clearance that way?Cool thing about Bronco is with coilovers from the factory aftermarket ones will be a piece of cake. 4WP seemed to fit those 37’s with just upper control arms in the front and probably just a basic rear lift and that should be enough for 99% of us. If you’re going above 40”+ tires and expect to run it hard you’re going to be doing a decent amount of fab work though...
It’ll add clearance but the problem with 40’s is purely strength related. From reading the JL forums the stock Rubicon axles do really well on 35’s and 37’s and can be run on 40’s but they get a bit iffy(Expect the Bronco to be similar in strength since it’s the same rear axle and front dif, just the IFS version). With how powerful the Bronco is and the fact it has an IFS front.... I’d personally stick to 37’s and keep it pretty bulletproof. If you’re going to 40’s you’re probably going to want to use some of those Ford performance parts at a minimum, axle shafts/5.38 gears etc. and even then I would be pretty careful in the rocks. Should do ok in the desert though! The problem with 40’s isn’t really at speed, it’s in 4-lo when you’ve got your tire bound up and you give it some cheddar.Do the modular quarter panels not open the possibility of adding wheel clearance that way?
I’m hoping so, I’d like to go with 35’s with no more liftDo the modular quarter panels not open the possibility of adding wheel clearance that way?
