I looked up the dimensions of the Jeep LJ a while back and, aside from width, the two door Bronco is pretty close.Height wise the roof lines are pretty similar but the Bronco is much narrower and it’s about half as long as the f150 (crew cab). The Bronco SEEMS to be bigger than a 2door JL/JK but not ridiculously so. It’s a good size.
JK
Not the only but it's the lowest trim with them. And look at the wheels.is the outer banks the only trim with mirror turn signals??
i'm guessing the trim compare tool hasn't caught up yet:
https://www.ford.com/suvs/bronco/2021/compare-models/#outerbanks|badlands
Correct. I meant LJ as in TJ Unlimited. The Bronco should be a little longer than the current Jeep two doors, based off posted dimensions.LJ or JL?? LJ is the longer wheelbase TJ. JL is the current gen Wrangler.
My sharpened sones and charcoal were in my other bag. I’ll do better next time!Terrible picture quality. Sharp as a tack, high pixel density, in focus, broad depth of field.
Didn’t you get the memo that all pics must be done using a flip phone from 1992, preferably with a scratched up lens?
at little dab of vaseline or chapstick on the lens will give us the expected quality!My sharpened sones and charcoal were in my other bag. I’ll do better next time!
JK
Appears to be Outer Banks. I'm not liking the roof at all.interesting. white door handles. can you tell what franken-trim it might be?
OuterBanks??
The wheels look a lot better in the real photo.Not the only but it's the lowest trim with them. And look at the wheels.
