timhood
Tim
Several
Don't base your decision on that nighttime photo behind the hotel. Those sodium lights give off a serious yellow cast.
timhood
Tim
Several
I think it is safe to say that the TOW capacity will be around 3500 lbs. This trailer is for sure between 2k or 3k barebone without anything inside. Anyways Jeep has 3500 so would make sense to just have the same capacity.
I think you mean it makes sense to have at least the same capacity. To me, it make sense to outdo the Wrangler in every way possible, which mean more towing capacity. :)
jaruss01
NJ
Have you looked at the Yakima Lock n Load rack? No screws needed. Any Yakima product will attach.
Not sure i like loose stuff strapped on. but it yakima has a cargo box that locks into the platform thats a different story.
timhood
Tim
Several
You can't make this stuff up...
People complaining and wasting energy over things that may or may not be available.
How else are people supposed to fill the time between now and June?! :ROFLMAO:
mustangfamily03
None
None
I agree even if it’s 100 lbs more like 3600. Still better. I understand when the tow rating goes up, ride quality and off road ability suffer some.
LarryZiegler
Larry
I have a Sears X-Cargo 20 (mfg by Thule) I have used on my current and past Pilots. I intend to use this cargo box on the Bronco
Ford Bronco Spotted: Bronco Badlands Sasquatch towing trailer with Outerbanks in the wild 3599FB7B-F0D9-4009-810F-EF9A8BBEF6B1
pan-y-cerveza
Manitoba
Tacoma Pro
Yep, anything that locks onto roof rails locks into the platform. It's basically a series of roof rails.
THEMANatwar
Bossier City, LA
1993 F150 Flareside, 2022 Bronco Badlands
Another unfiltered photo of the Cactus Gray Bronco Sasquatch in partial sunlight / shade.
Ford Bronco Spotted: Bronco Badlands Sasquatch towing trailer with Outerbanks in the wild Cactus Gray 4 Door Bronco Badlands Sasquatch
Ford why with that sunbleached gray... its okay but a normal black top would look 1000x better
Garemlin
Delaware
So if this is a molded in color hard top why is there a distinct seam that would imply the back passenger section is removable. I'm still seeing people insist daily that the molded in color is only 3 pieces. This would show its actually 4 pieces.
Ford Bronco Spotted: Bronco Badlands Sasquatch towing trailer with Outerbanks in the wild 59FE5585-056F-4D72-B968-CD37E2D1CD50
